EvoScan V.90 Is Ready
Old Sep 13, 2006 | 01:09 AM
  #91
codgi's Avatar
Originally Posted by MalibuJack
I've seen this before, its specifically looking for assemblies from the older versions of .NET therefore you'll have to install the older .NET 1.1.xxxx if you didn't already have it..
Odd shouldn't be necessary. Oh well. The best way to do this will be to actually uninstall the newest version, install the old one and then re-install the newest version. Don't want to attempt to register the old 1.1.xxxx files over the new ones cause that will cause problems going the other way.
Old Sep 13, 2006 | 10:27 AM
  #92
justchil's Avatar
Has anyone seen any issues with the "speed" column? I have a peak speak of 178 lol.. I may have hit 100 tops.
Old Sep 13, 2006 | 10:31 AM
  #93
MalibuJack's Avatar
Apparently there are assembly references to DLL's specific to 1.1, files which don't exist in the 2.0 I noticed this while working on something else in my own code on another project.. When I looked at this one, it had the same dependency.
Old Sep 13, 2006 | 10:32 AM
  #94
Rob W.'s Avatar
For a USDM EVO, you need to convert kph to mph. The data file looks like he labeled it as mph, but it's not correct.
Old Sep 13, 2006 | 11:18 AM
  #95
Guerillah's Avatar
Speed is definately off. Says I hit 138mph and I didnt even shift into 4th gear :/
Old Sep 13, 2006 | 11:44 AM
  #96
Guerillah's Avatar
Also the octane number is fubar from what I logged last night.. Stays at 100 and doesnt move. No more than 2 knock counts doing a 1-3rd pull multiple times. With 0.80 is reads 255.
Old Sep 13, 2006 | 12:04 PM
  #97
Rob W.'s Avatar
The octane number is still working fine, but it's now be corrected to a 0-100 scale (think of it as a percentage if you want). It's unitless anyway. You can see it in the data.xml file: octane = "100x/255".
Old Sep 13, 2006 | 12:13 PM
  #98
jcsbanks's Avatar
There are issues between cars in different markets. On a car from anywhere in the world the scaling is 2x with the unit km/h except for cars which have km/h to mph converters where the unit then becomes mph. The latter applies to the officially imported UK market cars.
Old Sep 13, 2006 | 04:20 PM
  #99
C6C6CH3vo's Avatar
I think the speed is off because it thinks your in two gears higher
Old Sep 13, 2006 | 04:51 PM
  #100
mrfred's Avatar
The scaling in the speed definition in v0.9 is not for mph (even though its labeled as such). Change ...Eval="2x"... to ...Eval="1.24x"...
Old Sep 13, 2006 | 05:00 PM
  #101
justchil's Avatar
Ty!
Old Sep 13, 2006 | 09:36 PM
  #102
C6C6CH3vo's Avatar
thanks fred
Old Sep 13, 2006 | 10:02 PM
  #103
mrfred's Avatar
np.
Old Sep 13, 2006 | 10:36 PM
  #104
codgi's Avatar
Fair enough.
Old Sep 14, 2006 | 11:25 AM
  #105
julianc's Avatar
Has everyone received their email link to download v0.9? Am I the only one still waiting?
