Evoscan 0.9 airflow volume reading
Old Sep 13, 2006 | 10:33 AM
MIevo8MR's Avatar
Question Evoscan 0.9 airflow volume reading
Does anyone know what the units are for the MAF aiflow volume? Has anyone logged the airflow volume for a stock airbox? Just want to compare.
Old Sep 13, 2006 | 11:10 AM
C6C6CH3vo's Avatar
There are several IX stock airbox logs posted around here
I f this is what your asking, OEM MAF measures airflow via a methaod beyond scope of my brain, however it feedbacks it to the ECU as a readable frequency (hertz, Hz), and it is this Hz that you are reading on the scan logs - 1603hz.
There are quite a bit of differences with this reading between airbox to aftermarket intake/filter. Allthough readings are way different, the airflow, volume, or velosity may not be different at all. This is because the stock MAF was calibrated to meter air for it's specific design and changing that changes the way the air travels accross the sensor
Old Sep 13, 2006 | 07:52 PM
Rob W.'s Avatar
Actually, I think what MIEVO was asking was about the new category in EvoScan 0.9. It is now defined as Airflow Hz (the one we used to all know and hate.. maxes out at 1603Hz, etc.) and "Airflow Volume" (which is a new one we have never seen before).
Old Sep 13, 2006 | 09:30 PM
C6C6CH3vo's Avatar
Oooops
vizi0n
Lancer Troubleshooting
Oct 23, 2016 06:55 PM
equinsu-ocha
20
Oct 22, 2014 10:59 AM
komilp13
Oct 15, 2010 07:09 AM
neemaD
Sep 22, 2007 08:21 AM
forum04pl
Aug 14, 2005 01:18 PM
