Mitsubishi Logger proof of concept code WORKS!
Old Sep 25, 2006 | 10:47 AM
  #46
Rob W.'s Avatar
Map tracing! Jack, you sure work FAST!
Old Sep 25, 2006 | 11:09 AM
  #47
MalibuJack's Avatar
The portion you see was fairly easy... once you calculate load, you can easily find the location in a simple grid.. Its extracting the data from the rom to fill in the axis values, the injector scaling values, etc, that is the hard part.. Plus I have quite a bit of real work to do outside of the logger project.. but I'm hoping I can get a beta out there to select users in a week or two.
Old Sep 25, 2006 | 11:22 AM
  #48
RazorLab's Avatar
Jack,
Again, awesome work. I would love to try out the beta. I was serious on my offer before in this thread. PM me your favorite brew and addy and I will send it out.
Old Sep 25, 2006 | 11:27 AM
  #49
MalibuJack's Avatar
LOL the brew isn't necessary..
But I'll be compiling my beta list next week.. I'll post a message when I'm ready and how many slots I have open.. The reason I don't want to do a wide beta right now is the sheer amount of e-mail volume I get as it is, and the amount of problems I may have to work through with the software, I'd much rather only deal with a few people to start.. If it gets distributed wider, the problem reports become unmanagable and become duplicated anyway..
Old Sep 25, 2006 | 11:34 AM
  #50
Rob W.'s Avatar
I'm sure just about all of us who frequent this forum would be happy (thrilled, actually) to beta test.
Do you plan to add support for AEM UEGO? Just curious.
Old Sep 25, 2006 | 11:48 AM
  #51
MalibuJack's Avatar
Initially I won't be adding wideband support, simply because I don't need it for my setup.. The first unit I'd support would probably be the TurboXS Tuner and Tuner Pro since there are many of those units out there with few if any tools to leverage them plus I have one here and can work with it easier. Once I get the base code down for that, then I can easily add additional units. I do think I want to focus on the wideband setups that don't get any love from any of the other products out there. (and I will only support units I can get physical access to.. It takes too long to add support to something you don't have available)
Everything outside of the basic logging, dashboard and map tracing features will be using external modules and being called from scripts within the program.. so if it doesnt exist, someone can easily add it if I didnt.. Doing this allows for much less overhead, and operates on several threads (though .NET is much better when doing multithreaded operations, its not perfect)
All of these different units have slightly different sampling rates.. so I want to create a module that samples at the fastest rate possible, and always has a value available to the software thats updated at the native rate of the wideband.
I also plan on supporting other external loggers, and data aquisition devices that you might not expect.. But I won't even entertain those until I have a beta out there.
Old Sep 25, 2006 | 12:10 PM
  #52
Rob W.'s Avatar
When the time comes that you are interested in adding a module for the AEM, please let me know. I'd be willing to send my unit to you for temporary bench test purposes.
I'm sure you'll be plenty busy with the other stuff for awhile, but like I said.. just let me know.
Old Sep 25, 2006 | 12:18 PM
  #53
MalibuJack's Avatar
You should see some of the cool modules I had built for my Utec Dashboard that were never released that I'm planning on converting.. a GPS tool (plots track points and can count laps, its also a basic timing program), a video recorder tool, records in-car video with data log data overlaid.. The advantage is starting all of these apps programmatically at the same time means the data is all in sync..
There is a legitimate reason I chose the TurboXS Tuner Pro though.. It has several inputs, two of which I use are EGT and Boost, that can be logged in the program.. Basically when I make a call to the modules I build, it will return a collection (a fancy array basically) of items that will go into the log.. For the Tuner Pro, it would be AFR, Boost, etc.. For other devices it would return other things.. But the module just needs to be in the same location as the program and configured.. Just working out the way to make it work and load correctly.. Then I'll publish specs for it and anyone can create an addon.
Old Sep 25, 2006 | 12:23 PM
  #54
MalibuJack's Avatar
Oh yah, someone mentioned an LCD Display.. I wrote a module for the UTEC dashboard that displayed a portion of its logger output on a Matrix Orbital display and took some input from the switch inputs on the VFD.. Its not very useful unless you have an in-car computer.. I discontinued developing the module when I got a portable touch screen display as a gift..
But, this is all in the future, since I am now developing a flash disk media (video) player (Embedded system) that updates its content over a broadband connection.. So its my primary focus for the next 2 weeks.
Old Sep 25, 2006 | 01:53 PM
  #55
chmodlf's Avatar
Man I'm getting a software stiffy from just reading this thread. I can hardly wait.
Old Sep 26, 2006 | 12:09 PM
  #56
MalibuJack's Avatar
Sample Log using randomly generated values from 0-255... I have a demo mode so I can get all the calcs in..
Code:
LogID,LogEntryDate,LogEntryTime,RPM,AccelEnrich,CoolantTemp,FuelTrim_High,FuelTrim_Low,FuelTrim_Middle,InjPulseWidth,AFRMAP,O2FeedbackTrim,O2Sensor,TPS,AirFlow,AirTemp,Baro,ISCSteps,KnockSum,TimingAdv,Battery,EGRTemp,OCTNumber,MDP,Speed,Load
0,2006-9-26,15:7:58.512,5593,53.33,0.77,193,3.51,4.31,660.45,-32.91,100.5,95,245,1.03,-55.7,92,166.25,242.33,-5.74
1,2006-9-26,15:7:58.621,406,59.22,17.15,71,4.10,58.82,1578.79,-46.48,28.5,177,249,9.97,524.8,254,215,4.97,-15.61
2,2006-9-26,15:7:58.730,4562,9.80,19.2,97,4.70,97.65,641.58,122.65,20,41,164,7.70,109,83,201.25,64.62,-11.42
3,2006-9-26,15:7:58.840,1468,58.04,51.2,96,4.56,63.14,1006.4,81.93,12,143,177,15.54,584.2,138,291.25,135.46,-11.54
4,2006-9-26,15:7:58.949,5375,50.20,17.41,14,4.86,5.88,622.71,98.64,62,39,120,11.73,225.1,39,298.75,206.30,-79.15
5,2006-9-26,15:7:59.59,4031,38.82,38.91,212,1.03,7.06,163.54,108.03,16,0,136,10.12,30.7,20,60,214.99,-5.23
6,2006-9-26,15:7:59.168,3593,35.69,5.63,193,2.28,49.02,327.08,108.03,12,150,43,1.76,292.6,69,277.5,237.36,-5.74
7,2006-9-26,15:7:59.277,2156,67.06,51.46,75,2.38,25.10,540.94,184.24,61.5,52,220,14.07,-39.5,84,172.5,24.85,-14.77
8,2006-9-26,15:7:59.387,5031,40.78,22.53,38,1.07,99.22,207.57,188.42,44,139,235,7.55,14.5,210,213.75,228.66,-29.16
9,2006-9-26,15:7:59.496,7937,33.73,27.39,138,2.67,42.75,811.41,135.18,78.5,124,173,6.89,389.8,74,47.5,167.77,-8.03
10,2006-9-26,15:7:59.605,1750,58.43,44.54,190,3.88,16.08,1289.45,142.48,121.5,16,15,7.04,279.1,30,36.25,54.68,-5.83
Old Sep 26, 2006 | 12:17 PM
  #57
MalibuJack's Avatar
And the XML File sample...
Code:
<MitsubishiLogger>
<config>test</config>
	<ECUItems>
		<Request LogReference="RPM" RequestID="21" Eval="31.25*x" Unit="rpm" Logged="y"	/>
		<Request LogReference="AccelEnrich" RequestID="1D" Eval="100*x / 255" Unit="%" Logged="y"/>
		<Request LogReference="CoolantTemp" RequestID="07" Eval="((-1.468*x+139.74)*1.8)+32" Unit="deg F" Notes="-2.7x + 287 F  ((-2.7x+287)-32)/1.8" Logged="y" />
		<Request LogReference="FuelTrim_High" RequestID="0E" Eval="0.78125*x" Unit="%" Logged="y" />
		<Request LogReference="FuelTrim_Low" RequestID="0C" Eval="0.78125*x" Unit="%" Logged="y" />
		<Request LogReference="FuelTrim_Middle" RequestID="0D" Eval="0.78125*x" Unit="%" Logged="y" />
		<Request LogReference="ECULoad" RequestID="1C" Eval="5*x/8" Unit="%" Logged="y" />
		<Request LogReference="InjPulseWidth" RequestID="29" Eval="0.256*x" Unit="ms" Logged="y" />
		<Request LogReference="AFRMAP" RequestID="32" Eval="x" Unit="afrmap" Logged="y"	/>
		<Request LogReference="O2FeedbackTrim" RequestID="0F" Eval="0.78125*x" Unit="%" Logged="y" />
		<Request LogReference="O2Sensor" RequestID="13" Eval="0.0195*x" Unit="V" Logged="y" />
		<Request LogReference="TPS" RequestID="17" Eval="100*x / 255" Unit="%" Logged="y" />
		<Request LogReference="AirFlow" RequestID="1A" Eval="6.29*x" Unit="Hz" Logged="y" />
		<Request LogReference="AirTemp"	RequestID="3A" Eval="((-0.58*x+90.96)*1.8)+32" Unit="deg F" Notes="-0.35x+58 For deg F ((x-34)*1.8)+32" Logged="y" />
		<Request LogReference="Baro" RequestID="15" Eval="x/2" Unit="kPa" Notes="0.00486*x Bar" Logged="y" />
		<Request LogReference="ISCSteps" RequestID="16" Eval="x" Unit="steps" Logged="y" />
		<Request LogReference="KnockSum" RequestID="26" Eval="x" Unit="count" Logged="y" />
		<Request LogReference="TimingAdv" RequestID="06" Eval="x-20" Unit="deg" Logged="y" />
		<Request LogReference="Battery" RequestID="14" Eval="0.0733*x" Unit="V" Logged="y" />
		<Request LogReference="EGRTemp" RequestID="12" Eval="-2.7*x + 597.7" Unit="deg F" Logged="y" />
		<Request LogReference="OCTNumber" RequestID="27" Eval="x" Unit="Trim" Logged="y" />
		<Request LogReference="MDP" RequestID="38" Eval="1.25*x" Unit="%" Logged="y" />
		<Request LogReference="Speed" RequestID="2F" Eval="(2*x)*0.621371192" Unit="MPH" Logged="y"/>
		<!-- Place all Complex requests below this line -->
		<Request LogReference="Load" RequestID="FF" Eval="5*InjectorScale*(InjectorPulseWidth-InjectorLatency)/AFRMAP" Unit="Site" Logged="y" />
	</ECUItems>
</MitsubishiLogger>
Old Sep 26, 2006 | 01:17 PM
  #58
AMSTuning.com's Avatar
Impressive. Would love to try this out with a load bearing dyno.
Old Sep 26, 2006 | 01:32 PM
  #59
MalibuJack's Avatar
I'm putting together my Beta list next week, I'll make sure you guys are on it.
Old Sep 26, 2006 | 04:37 PM
  #60
otter's Avatar
EvoM Administrator
If you need a beta guy on a non-Evo car, lemme know
