ECUEdit Now Supports EVO Logging!!!!
Old Oct 4, 2006 | 02:03 PM
  #46
Noogles's Avatar
Originally Posted by epifan
Ok, I show how quickly you can build custom calculated logs in ecuEdit, built log based map table and some other features...
All this features are availiable in TRIAL version of ecuEdit. Also all this features included in registered ecuEdit Logger Edition suite
1. Open Log file in ecuEdit by [Ctrl]+[L]
2. Press right mouse button on Log param list box and choose Add Custom Log..
Input log param name and expression for calculation, for exampe Load: 5*513*([value]-0,432)/[value2]
and choose Param for [value] - Injector Pulse Width and for [value2] - AFRMap.
Press [Add] button. Now we have new calculated log parameter.
You can save all selected parameters as full log or save only selected log area.
3. Select WOT interval to analyse ECU data by pressing [Ctrl]+[F]
There you are choose Log parameter and "data from/to" interval for selecting.
You can adjust selected interval by changing Start/End trackbars (blue highlighted on screenshot)
4. Now select Custom Page by pressing [Alt+5]
Select "Load" for X Axis, "RPM" for Y Axis and any parameter for "Data"
Activating Round functions for X and Y axis. Input 10 for Load and 500 for RPM round.
After double click on table cell you can view all log entry in this cell.
5. You can view this table as bubble 2d chart
Bigger bubble have bigger value of log entries.
6. You can view "road dyno" for this WOT on "Dyno" Page by pressing [Alt+6]
Better build DYNO by RPM method, so unchek "Vehicle Speed" check box.
Power and Torque values will be not correct (because gear rates and mass on mitsu different, i'm not include mitsu data in XML yet) , but you can view power/torque curves - they are approximately right
Next example will show a real map trace
When using the desktop dyno it's saying i have 15,000+ hp and 15000+ tq, lol
i used the same setting that you did.
Any chances you will get the XML definitions for ECU jm9693 incorporated any time soon?
I just realized i can't even lod correctly without it.
Old Oct 4, 2006 | 10:33 PM
  #47
epifan's Avatar
This because you are using EvoScan log which don't have log step time in msec (this is general format), first column in evoscan log is line counter. So if you car accelerate by 1msec from 60 to 61mph this mean that your car have about 1500hp
I send e-mail to you with descriptions.
Old Oct 5, 2006 | 03:20 AM
  #48
Evo_Jay's Avatar
Originally Posted by mchuang
Wow nice, can it actually edit the ecu since it is called ecu edit lol maybe i need to go read up on it. I do see a load calculation
+1
Can it edit and flash EVO maps yet??
Old Oct 5, 2006 | 03:27 AM
  #49
epifan's Avatar
Originally Posted by Evo_Kid
+1
Yes, ecuEdit can edit any ECU bin files (by maps), including EVO. I have some EVO XML descriptions collection, but only for registered users. You can see on map trace screenshots window with EVO maps list
ecuEdit can't flash EVO, yet...
Old Oct 5, 2006 | 03:51 AM
  #50
mchuang's Avatar
So then you still have to use ecu flash to write the edited bin to ecu or can you edit bin on the fly realtime?
Old Oct 5, 2006 | 06:45 AM
  #51
epifan's Avatar
EcuFlash can be used for read ECU and flash after editing.
Realtime flash is impossible.
Old Oct 5, 2006 | 09:03 AM
  #52
Noogles's Avatar
I got it working now, boy do i feel stupid but this real time logger and map tracer is absolutely amazing.
I've got it to hit almost every single cell on the map in one drive to work and my drivability is much better. Can't wait for the sektop dyno to include the evo 8 info so that it'll be more accurate.
Old Mar 22, 2007 | 08:33 PM
  #53
roberttonge's Avatar
ECUedit
Please advise where i can downlaod a trial of this program as it looks really interesting I can be emailed at roberttonge@cwdom.dm
Old Mar 22, 2007 | 10:53 PM
  #54
epifan's Avatar
www.epifansoft.com
Old Oct 31, 2007 | 05:26 PM
  #55
trinydex's Avatar
anything new?
Old Oct 31, 2007 | 11:25 PM
  #56
epifan's Avatar
Originally Posted by trinydex
anything new?
v3.0 major feature is support EVO 7-9 ECU read/flash
other features description here
Old Nov 1, 2007 | 12:15 AM
  #57
cpoevo's Avatar
Whats the difference between Pro, Standard, and Logger besides the price. Could you post a few screen shots of the real time logger and map tracer. I was just getting ready to purchase DLL and I might just buy Ecuedit instead. I just want to see what all it offers. I downloaded the trial version and like what I saw there.
Old Nov 1, 2007 | 12:24 AM
  #58
epifan's Avatar
Logger version includes only SSM,MUT,OBDII logger and logviewer
Standard = Logger version + Map Editor (with map tracer and etc)
Pro = Standard + Flash support (Subaru 2.0turbo, Evo7-9)
You can see screenshots of map tracer at this thread on page 3.
Logger screenshots you can see here
Old Jun 10, 2009 | 04:45 PM
  #59
ATE BALLER's Avatar
So, what exactly will standard do? It says logger + editor, but does that mean editing logs, or editing the ecu? I just want to rescale my MAF sensor for a bigger housing.
Old Jun 10, 2009 | 06:48 PM
  #60
dude's Avatar
Back from the dead!
How about the thread on "rescaling your MAF" by sophiesleeps?
