Logging Load
Download the correct version of Load calc. for your version of EvoScan.
You just drag the excel doc and drop it into the calculator and it farts out the correct load in an extra column, and is dead on too
Where can I find this Load Calc?
http://www.aktivematrix.com/forum/dl...ile&file_id=24
Just use the same stuff you use to run the EvoScan and you'll figure the rest out on your own. Any problems you run into getting started likely been encountered so helpful info is either on here (?f=179) or on the Matrix.
Question how do you save it as a excel doc ???
Originally Posted by djd24
When I look at my evoscan logs, I see that my ARFMAP column is blank. Why is this?
Originally Posted by MalibuJack
Look at the original file, I'll bet its not in the original too.. Its possible its blank because its not enabled.. I have only seen one log submitted to me that had the AFRMAP column there, but blank.. I assumed it was because it was not selected..
Nice call - it wasn't selected. I never even scrolled down in the program to see if it was selected. I also received an error message from your load calculator program...I'm guessing this is because there were no values in the ARFMAP column?
okevolutionVIII
Jan 1, 2014 10:15 PM
darksideauto
Lancer Engine Management / Tuning Forums
Jun 13, 2012 05:34 PM
