Odd load spike. Log inside.
Old Jan 12, 2010 | 12:41 PM
dmoevo's Avatar
Been seeing this in my logs recently, Wondering if anyone has seen something like this, or can explain it. You can see in the pics and the log that peak load hits before peak boost. At its highest point, 365% its only at 27 psi. The boost continues on until 35psi, where the load is only at 320ish. Shouldnt the highest load be at the highest boost? Or is it that my laptop is not capable of logging fast enough?
Old Jan 12, 2010 | 03:08 PM
black E's Avatar
looks like alitle logger lag...are you sure your MAP sensor is scaled correctly?
Old Jan 12, 2010 | 03:40 PM
dmoevo's Avatar
all scaled correctly. other than the fact that the "map comparison" table is supposed to be changed to 1.23 and ecuflash will only accept 1.24, dont think that would do it.
I would think its just the laptop lagging, but it only does it on my car. Ive tested on friends cars.
Old Jan 12, 2010 | 07:33 PM
rolly1818's Avatar
Registered User
its the way u view the logs, change the way ur viewing it in evoscan.
if thats not it then its pretty weird your logs are so smooth (relatively speaking).
Old Jan 13, 2010 | 06:57 AM
tephra's Avatar
thats normal.
think about where load is measured and where psi is measured.
Old Jan 13, 2010 | 09:06 AM
fostytou's Avatar
EvoM Community Team
Originally Posted by tephra
thats normal.
Ding ding ding!
Raceghost
Dec 14, 2016 12:47 PM
stunt2
May 25, 2012 01:46 PM
recompile
Aug 29, 2007 08:45 AM
Sayno
Apr 15, 2007 07:04 AM
redza
Apr 4, 2007 12:48 PM
