Question about boost level and knock with a flash
Old Sep 28, 2006 | 09:54 PM
stingerbtry's Avatar
So I got a new rom from a highly regarded tuner on here and while everyone else seems to feel tons of power and no knock I am not getting the same results. I have a stock IX with nothing but an HKS hybrid drop-in and this was an email flash. Log attached...
I have a late model IX which apparently had the boost cut back some from the earlier models and I only boost maybe 1.2 bar max tapering back to 1 or below. I am having speedelement install a Hallman mbc on Monday and my question is how will being back at "normal" boost pressure (~20psi) affect my tune and should I expect better or worse than I have right now with the reults from these logs? The person that did the flash said that changing the boost characteristics would change the tune quite a bit and that he would need new logs once the mbc is in to be able to adjust it which is fine but I want to get an idea of what I should expect and if it will be safe to run the current flash with the higher boost. Any insight would be greatly appreciated.
Old Sep 28, 2006 | 10:00 PM
Rnm's Avatar
Rnm
Was this a custom flash?
Old Sep 28, 2006 | 10:04 PM
Sorry I updated my original post. My car is a stock IX with nothing but a drop-in filter and this was just an email flash.
Old Sep 28, 2006 | 10:06 PM
mrfred's Avatar
Seems like quite a bit of ign advance at 3500 rpm. Was the car WOT for that run?
Old Sep 28, 2006 | 10:09 PM
RazorLab's Avatar
It looks like it doesn't hit full boost until 4k so I assume he didn't go WOT till after 3k.
Old Sep 28, 2006 | 10:11 PM
Originally Posted by razorlab
mmm dynoflash.
It actually wasn't. Those logs were waaay worse.
Old Sep 29, 2006 | 03:35 PM
New WOT log attached.
Old Sep 29, 2006 | 03:41 PM
Ralph's Avatar
New log ..... you should probably go WOT at 2500~ to see spool earlier.. plus, let the car tap the rev limiter also. This is so you can see the WHOLE picture
Old Sep 29, 2006 | 04:11 PM
nj1266's Avatar
Exactly. The log does not tell us much. Start WOT @ 2500 rpm and go to 7400-7500 rpm and then lift. Do that in 3rd or 4th gear and them post the log.
Old Oct 2, 2006 | 06:59 AM
11SECEVO's Avatar
I've been saying this is the case with the Newer IX's based on Mine (99.8mph)and Others that have run thier Stockers at the track and come back with Sh*ty LOW mph's...........and NOW apparantly I Can't even get mine Flashed!!!
Old Oct 2, 2006 | 06:08 PM
cij911's Avatar
Both 11 sec and stinger should contact John (at Jestrtuning) IMHO.....John will set you up with a great base flash or do an awesome custom tune.
11 sec -- we may have a custom tune day in VA with John if you are interested. You could get before and after dyno results to show your gains as well if you are interested...
Old Oct 2, 2006 | 06:53 PM
11SECEVO's Avatar
Thanks, I'll DEFINETLY keep it in mind
Old Oct 2, 2006 | 09:23 PM
TTP Engineering's Avatar
There is nothing wrong with those knocksums.
We need 2500rpms to 7500rpms logged in 4th gear.
Then a log rolling into a 1-2-3-4th gear pass like drag racing.
This should provide ample info.
TTP has both E-flash bases as well as full RemotEflash(tm) custom tunes available. If interested, send us a PM. Thanks
Old Oct 2, 2006 | 09:58 PM
All is well now but thanks for your input everyone. I had speedelement install a hallman mbc and dyno tune my car. I'm now putting down 270.4awhp/290.8awtq on EIP's mustang dyno and am very happy. I should've just went with a custom dyno tune in the first place.
Old Oct 2, 2006 | 10:08 PM
Well yeah....
Andy is a good tuner...
