whats wrong with this pic
Old Sep 29, 2006 | 10:20 AM
matt55's Avatar
rpm/load scale is off .
http://img244.imageshack.us/img244/9...tt55piccx3.png
I think its just the RPM/Load #'s are off but the map it slef is right .
So can i just go and edit the rpm/load and every thing will work ok ?
Thanks
Old Sep 29, 2006 | 01:07 PM
mrfred's Avatar
You're using the wrong definition for your ECU. You'll have to track down the correct definition for your ECU. Don't try to changes the axes values. That data represents something else in the ECU, and if you change the values, you're changing something besides axes values.
Old Sep 29, 2006 | 01:28 PM
20psiMR's Avatar
Ya you have the wrong xml file loaded. Is that for your ecu? Are you trying to load a jdm rom or something if its not yours? Under parameters what does it say for definition #?
Old Sep 30, 2006 | 06:40 AM
matt55's Avatar
not using the jdm rom , so how would one go about changing definition for your ECU ?
Old Oct 1, 2006 | 09:39 PM
C6C6CH3vo's Avatar
I had similar problems when I chose the wrong ECU identifier (part # on ECU lable) for my 04.
Reinstalling Ecu,flash with correct ID fixed it (except for idle step lookup)
Jimbo8558
Jul 28, 2013 05:12 PM
EvoIXPilot
Apr 12, 2013 09:56 AM
shadow1
Apr 4, 2009 01:43 PM
justboosted02
Dec 16, 2008 01:25 PM
evo4mad
Oct 13, 2008 10:56 AM
