Throttle hang and the Idle Stepper Table
Old Jan 19, 2010 | 12:30 PM
  #421
Boosted Tuning's Avatar
Originally Posted by McLaren F1 2003
anyone?
Here ya go
Code:
    <table name="ISCV Demand RPM Adder (Moderated by Baro, IATS) (FFFF6EA8) (sub_204B6) [sub_1EFC0]" category="Idle" address="672a" type="2D" level="2" scaling="ISCV_AX2_8">
        <table name="RPM" address="802a" type="Y Axis" elements="10" scaling="RPM"/>
    </table>
    <table name="ISCV Demand RPM Adder [rpm > 4500, load > 170, speed > 12 mph] (sub_1EFC0)" category="Idle" address="65de" type="2D" level="2" scaling="ISCV_AX2_8">
        <table name="RPM" address="7fb0" type="Y Axis" elements="10" scaling="RPM"/>
    </table>
    <table name="Decel Fuel Cut Delay #1" category="Fuel" address="3d6e" type="2D" level="2" scaling="uint8">
        <table name="Load" address="6fc6" type="X Axis" elements="7" scaling="Load"/>
    </table>
    <table name="Decel Fuel Cut Delay #2" category="Fuel" address="3d82" type="2D" level="2" scaling="uint8">
    </table>
Old Jan 19, 2010 | 03:39 PM
  #422
McLaren F1 2003's Avatar
^^^thanks for the code...
Appauldd has setting for 4 different decel fuel cut delay tables, though.
your code only contains info for 2 of those tables.
does 88590015 not have 4 tables? or do those other 2 just not matter?
thanks
Old Jan 22, 2010 | 12:57 PM
  #423
*edit* nevermind, i found what i needed
and i believe i have the throttle hang cured. it seems to be engine braking like a normal car haha
Old Feb 5, 2010 | 07:59 AM
  #424
David Buschur's Avatar
appauld and boosted tuning, thanks to both of you. Finally it seems to be cured, I had an '06 here I couldn't let leave because the throttle hang was so bad, I thought it was actually dangerous to drive like it was.
Something odd though if you don't mind. I added the data to the XML for the 88590015 ROM and the ISCV tables only show the RPM column and half the column that needs to be set to 0. I can not expand it larger to see those columns and they don't seem as though they can be modified becuase of only half the cells being shown. By half I mean literally only half of the cells can be seen, as in CUT in half. It looks like if you could drag the table to the right to expand it then it would be correct but it won't allow that either.
Also I only have Decel Fuel cut delay 1 and 2 that show up, is there a 3/4?
The car is fixed so I guess it doesn't matter, just pointing it out.
Thank you both VERY VERY MUCH.
Old Feb 5, 2010 | 08:02 AM
  #425
Appauldd's Avatar
No prob David....we are here to help.
As for the 8859 rom...are you certain you have an accurate xml listing for that rom? I sounds like the address and/or table(s) is missing.
Old Feb 5, 2010 | 08:03 AM
  #426
Does the XML mod exist for the 2005 ROM's too?
Old Feb 5, 2010 | 08:09 AM
  #427
Appauldd's Avatar
David....use this http://www.globalshare.net/evo-mod/v...phraMod-V7.zip
It is the full v7 version of 8859 with tephra mods.
Old Feb 5, 2010 | 08:36 AM
  #428
I have to be honest, most of the time when I start messing with these XML's I get feeling dumber than a rock.
The link you sent me takes me to a zip file, that file size when I add it to my folder shows it is 13KB. I have another file already in there that is labeled, TephraMOD-88590715 that is 65KB. Shouldn't that much larger file already contain the information in the 13KB file and about 5 times more?
I am asking, I hope this doesn't sound like I am being some type of jerk. This stuff is frustrating to guys like me with NO computer knowledge! haha
Old Feb 5, 2010 | 08:44 AM
  #429
Appauldd's Avatar
That link was the original link posted in the v7 thread.
Hmmmm. I haven't played with an 9 roms. I guess it wasn't as complete as the other rom versions.
I will do some hunting for you.
Paul
Old Feb 5, 2010 | 08:48 AM
  #430
Appauld, do you have the XML definitions (I think I'm asking for the right thing) for the 2005 ROM to fix this? I've had a few 2005's that were horrible. I believe the definition that boosted tuning posted is for the 2006, has to be I guess since it worked in the car I fixed this morning!
Would you like me to post the big Tephra xml I have?
Old Feb 5, 2010 | 08:49 AM
  #431
Appauldd's Avatar
David....send me your xml file. I will find the problem and send it back to you.
same sn as here at gmail dot com.
Paul
Old Feb 5, 2010 | 12:31 PM
  #432
i had that same problem
you are missing these scalings:
<scaling name="ISCV_AX2_8" units="% Demand" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="200" inc="0.5" storagetype="uint8" endian="big"/>
<scaling name="ISCV_AX2_16" units="% Demand" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="200" inc="0.5" storagetype="uint16" endian="big"/>
Old Feb 5, 2010 | 12:33 PM
  #433
Appauldd's Avatar
Good call....I saw that too. I am working on building a better defined 8859 xml for David. The one he sent me was missing a lot and had all kinds of crazy tables that are not used.
Old Feb 5, 2010 | 01:08 PM
  #434
lan_evo_mr9's Avatar
I tried searching for the def's/patches for the "decel fuel cut" and came up with nothing. That's wrong, I came up with too many threads which I searched through the first 5 and gave up after 30 minutes.
Can someone post the def's for 88590015 please? It would be much appreciated.
EDIT...NM, I'm stupid.
Edit (Again)......So there's only 2 decel tables for 885?
Old Feb 5, 2010 | 01:26 PM
  #435
mclaren, while I am waiting on someone who actually knows WTF is going on (Thank you appauldd!!) I tried the fix you sent me. I put it in with the fuel tables and it didnt' work but did figure out for myself it has to go at the top with the other scalings That is what was wrong and the iscv tables do work correctly now. Thank you.
I try.
