HOW TO - Control boost using ECUFLash and the stock boost solenoid
Old Feb 27, 2007 | 08:32 AM
  #181
jcsbanks's Avatar
Needs custom modifications to your ROM. This is a complex area/advanced topic, there are threads about it. Most people get away with looking at their ignition timing to see what cell they're in.
With standard induction the graph I posted should be a good guide for most.
Old Feb 27, 2007 | 08:44 AM
  #182
heyzeus11's Avatar
Originally Posted by Mr. Evo IX
I found running the stock bcs that if I went WOT in 4th gear around 4000 rpms I would seriously overboost as well, my car had the stock boost pills in it and I would measure 24.5 psi on my AEM Truboost gauge / controller.
Try modifying your Error Correction map.
Old Feb 27, 2007 | 01:00 PM
  #183
spdracerut's Avatar
I zeroed out my boost correction tables yesterday and the boost is pretty much rock steady; pretty much acting like a MBC in that it's not constanty trying to adjust itself.
Today, I lowered the values in the boost correction table from the stock values, and the boost stays more stable (makes sense right?) compared to before. I also tried to match up the values in the boost desired engine load tables to match what I was actually getting.
If your actual load matches your desired, no boost correction and therefore the boost pressure should stay more stable.
Old Feb 27, 2007 | 01:11 PM
  #184
jcsbanks's Avatar
Sounds like you've got it nice. Now all you want the closed loop control boost control for is to make sure the held boost is the same between gears and different driving conditions/temperatures even though the peaks will vary. Smaller correction values are nice to make it smooth and avoid oscillations as long as it quickly comes to target.
Old Feb 28, 2007 | 03:59 AM
  #185
MR's Avatar
MR
When u mentioned that u remove the taper by using the max wastegate duty, are you referring to inputting the values to 100 max or reducing this 100 figures?
Please advise...
Originally Posted by Jhero23
After a few more adjustment on Ecuflash I was finally able to remove the mbc effect (less boost on low gears, more boost on higher gears), this was done by using the boost error correction. I strongly suggest you guys messing with these intead of just changing everything to zero. Have you guys ever wonder why the factory set, the first four to 8.0 and the last four to -13.0? By messing with the boost error correction I notice that the first four adds more loads (more boost) on lower gears, and the last four put less loads (less boost) on higher gears:
-20.0 = 8.0
-17.5 = 8.0
-15.0 = 8.0
-12.5 = 8.0
-10.0 = 6.5
-7.5 = 4.5
-5.0 = 3.5
-2.5 = 2.0
0.0 = 0.0
2.5 = -1.5
5.0 = -3.5
7.5 = -5.0
10.0 = -6.5
12.5 = -13.0
15.0 = -13.0
17.5 = -13.0
19.8 = -13.0
I also notice that when the boost control load offset is set at 80, the ecu is actually removing loads on 3rd gear, by changing this to 100 the ecu did not start removing load till 5th gear. I set my boost to 22 psi on 3rd gear, remove the taper by using the max wastegate duty, then lower the boost on high gears by changing the last four to -20.0:
12.5 = -20.0
15.0 = -20.0
17.5 = -20.0
19.8 = -20.0
I also notice that having both restrictor pill actually helped removing the spike, when I remove the one close to the solenoid all I get is spike on low rpm.
Just remember all evos are different, let me know if this works for you.
Old Mar 9, 2007 | 07:07 AM
  #186
marksae's Avatar
Does anyone know if the ECU uses feedback from the stock MAP sensor for error correction or load calculation at all? The reason why I'm asking is because I currently have my stock MAP sensor disconnected and have a GM 3-bar MAP sensor wired in.
I'm trying to tweak my P2 boost control and increasing the wastegate duty cycle has made no real difference. I only had time to increase the wg duty cycle by 3% across the board though. I'll try increasing it more when I have time this weekend.
Old Mar 9, 2007 | 08:38 AM
  #187
Mr. Evo IX's Avatar
I dont think the ECU uses a map sensor to determine load. The stock map sensor only reads vacuum to about 3 psi. I think the ECU calculates load based on injector duty cycle / maf frequency / rpm or something like that.
Old Mar 9, 2007 | 08:41 AM
  #188
marksae's Avatar
Yeah, that makes sense. I'll try making changes in larger increments next.
Old Mar 9, 2007 | 09:09 AM
  #189
Dinothegreat's Avatar
subscribed
Old Apr 7, 2007 | 01:41 PM
  #190
TouringBubble's Avatar
Originally Posted by Evo_Kid
I now know why puttin all 159s in the desired load table make taper go away..
Say you hittin 240 load @ 3500 and 200 load @ 7000.
If all you tables say 159 + the offset, 80, that mean from 3500-7000, you target load is 240.
Now at 3500 you hit that, so the WG duty doesnt change but at 7000 your @ 200, which is 17% under target
Turbo error corr. @ -17% is +8 WG duty.
Evo_Kid, as you know I'm trying to wrap my head abound this theory. Reading the above popped a thought into my head ...
Instead of maxing out the desired boost tables, why not increase the offset? It would, in theory, allow you to decrease all cells in the desired boost table and achieve stock response while allowing control of the boost curve with the desired boost table along with the Max WGD tables.
This would also affect all 3 desired boost and WGD tables, which I would consider desirable since we still aren't sure if the tables are gear based.
Has this been tested at all? I do not have boost logging abilities and am a little hesitant to play with these setting too much.
Old Apr 8, 2007 | 09:01 AM
  #191
Bump for thoughts on the above ...
Old Apr 8, 2007 | 12:22 PM
  #192
cij911's Avatar
I have done this with my 9....I have an inline bleeder to the BCS and have the offset to 100...I can control boost extremely well and unlike the MBC setup, the EBC / ECU / BCS setup seems less prone to boost creep in higher gears....
Old May 14, 2007 | 01:39 PM
  #193
Jeff_Jeske's Avatar
I want to run 25psi 24/7 (alchy injection). I dont really care if it initially spikes higher the settles to 25psi as I am not seeing any knock at all. Is anyone having luck holding higher boost with the BCS?
I'm currently using an EBC but it gets a little shaky up top. I see boost drift from 23-25 psi through most of fourth gear. I've been told that the EBC isn't the best at high boost and I'm looking for a replacement. Is the ECU capable of holding higher boost levels (with the new wastegate pill)?
Old May 14, 2007 | 03:27 PM
  #194
mrfred's Avatar
25 psi is no problem with the stock BCS (if setup correctly). Control over boost across the rpm range can be very good too.
Old May 14, 2007 | 03:56 PM
  #195
Evo_Jay's Avatar
This was archived with just a modifed pill and no desired load target and error correct tuning. With more tuning you could make it better..
Attached Thumbnails HOW TO - Control boost using ECUFLash and the stock boost solenoid-25-psi.jpg
