HOW TO - Control boost using ECUFLash and the stock boost solenoid
Old Oct 13, 2006 | 05:55 AM
  #91
Evo_Jay's Avatar
Originally Posted by mchuang
Well I am at 20psi now and I am trying to get to 23psi wastegate set at 100% so I will remove restrictor just like Gen1 Dsm's and Gen2 Dsm's use to. They have no management and use to get 2 or 3 extra psi. So I figure it should be the same for us. I think I may drop it to 80% and put error correction back just in case and see what happens.
If your still running the stock pill near the turbo, then I would definantly have on error correction.
Error correction is the last thing I'm working on setting-up then my boost control will be done.
Old Oct 13, 2006 | 06:02 AM
  #92
heyzeus11's Avatar
Originally Posted by Evo_Kid
I wonder if the duel solenoid setup can be installed on a USDM IX.
If it can be installed on a USDM IX, I assume it can be installed on an USDM VIII?
Old Oct 13, 2006 | 06:23 AM
  #93
Evo_Jay's Avatar
Hopefully
Old Oct 13, 2006 | 06:34 AM
  #94
jcsbanks's Avatar
We're not at the stage yet of having characterised all the inputs and ouputs on the ECU sockets and to which pins on the actual microcontroller they ultimately attach to. There may well be multiple unused inputs and outputs right there wired to the sockets, which would be exciting for doing custom stuff like this.
Don't know about the current handling of doubling up two solenoids on the one feed either, could blow the driver circuit.
I think the experimentation with restrictors/lines/actuator is good, or just changing to a 3 port solenoid if you find one resistance matched.
Old Oct 15, 2006 | 02:57 PM
  #95
mosorio29's Avatar
hi
I can't find a drill bit here in mexico, i just drop a #40 nitrous jet into the hose and reintalled , work fine , I got 22 psi at 70WG duty, but when my car hit about 5000 stop pulling hard, i think its fuel cut . can I fixed with the ecuflash?
tks viva mexico!!
Old Oct 15, 2006 | 05:12 PM
  #96
mchuang's Avatar
Originally Posted by mosorio29
hi
tks viva mexico!!
you should be able to
Old Oct 15, 2006 | 06:15 PM
  #97
mosorio29's Avatar
Talking
how?
Old Oct 15, 2006 | 06:21 PM
  #98
mosorio29's Avatar
Talking
how?
Old Oct 15, 2006 | 06:22 PM
  #99
mosorio29's Avatar
Talking
how?
Old Oct 15, 2006 | 07:44 PM
  #100
heyzeus11's Avatar
I went out and played with boost desired load target. Lowering it from 159 to 60 did nothing.
I dont think it has any control of the boost, but I do think its very important to correct boost control and a stable boost curve.
Going back outside right now to try a couple new thing.......
I havnt tried to lower the Desired Load values to see if it would lower the boost values I saw; but earlier today I increased the load values by ~10-15 units higher then what I normally see between 4000-6000rpms in the Desired Load #1, and #2 maps, and filled in the Error correction map. I dont have a map sensor I can log my boost with so I used my digital camera to show the results I saw. Both were in 2nd gear within 10 min. of each other, and after the car had been running and warmed up. My Wastegate Duty values are above in one of my previous posts, and I made no changes to the Wastegate Duty values. You can see both here, "http://members.***.net/benandkim1/index.html". Some time this week I will try it with load values ~10-15 units below what I would normally see. This is what my Error Correction map looks like,
-20.0__9.5
-17.5__9.5
-15.0__9.5
-12.5__9.5
-10.0__8.0
-7.5___5.0
-5.0___4.0
-2.5___2.5
0.0___0.0
but it wont hold much past 20psi past 6k, basically like a long spike.
Old Oct 15, 2006 | 07:47 PM
  #101
heyzeus11's Avatar
wow triple post.
Old Oct 15, 2006 | 07:52 PM
  #102
heyzeus11's Avatar
how?
did you increase your boost limit?
Old Oct 15, 2006 | 07:56 PM
  #103
Evo_Jay's Avatar
I believe the reason rasing the load raises boost some what, and only during taper is this...
Your load tapers just like boost. So when you raise the load, where taper would normally be, the engine cant hit the higher load, so the error correction table tries to add more WG duty (the WG duty can really go to 127.5, but the 27.5 part is for error correction). Because of this the boost goes higher. Its not really going higher because you increased the load, its going higher because error correctionn is adding WG duty.
Refer to post #33 in this thread for more on this.
Again, this theory, like my other theories, is just that, a theory and therefore might be wrong/incorrect.
Old Oct 15, 2006 | 11:13 PM
  #104
mosorio29's Avatar
sorry about the triple my isp sucks!
boost limit 255 all rpms
Old Oct 16, 2006 | 12:16 AM
  #105
mchuang's Avatar
Try 319 that is what mine is set at
