Tuning for Intake?
Old Oct 15, 2006 | 11:25 AM
coolguycooz's Avatar
Tuning for Intake?
Ok so everybody is saying the stock air box is good for a lot of hp. And if you get an intake and cone filter you have to tune for it.
What exactly do you tune about it, do you tune the added air flow? would would you change as far as timing and fuel maps go generaly? or are there other things you change in the ecu flash ?
Old Oct 15, 2006 | 12:04 PM
jcsbanks's Avatar
The elegant/"correct" to do it would be to adjust the airflow meter scaling. However, because the exact processing of the airflow signal is relatively poorly understood, many will just scale the fuel and timing maps to suit.
Closed loop stuff will give away the changes from the fuel trims.
Open loop stuff from your wideband.
Timing from your knock sum/octane number/knowledge of sensible timing on these engines/your setup.
The stock airbox is limited. At 7000 RPM at 21 PSI on pump fuel on a IX with exhaust, pump and HKS hard pipes I was getting a 1.5 PSI depression from atmospheric pressure at the airflow meter. This was halved by removing the airbox lid and securing the filter - you've just gained 5% air density before the compressor which will either allow more boost and airflow, or allow the turbo to run at a slower speed by opening the wastegate (so improved compressor efficiency and lower exhaust manifold pressure, less pollution of the fresh air charge from the end gases etc). Some have had similar results by cutting a hole like the one for the snorkel in the lid of the airbox on the opposite side to the snorkel. This is away from most of the hot air. Doesn't seem to upset MAF readings, looks stealth, still increases induction noise a bit. FWIW with the airbox lid off you can record gains in acceleration and on the dyno.
Old Oct 15, 2006 | 02:23 PM
so the main thing that gets thrown off is the scaling of the mass air flow sensor? when you throw on a cone filter? And people compinsate by fuel/timing maps ?
does somebody design an intake and filter , that keeps the MAS signal stable?
Old Oct 15, 2006 | 03:31 PM
jcsbanks's Avatar
The airflow pattern over the sensor is changed. On some filters this may not be significant. On others it can make a tuned car lean enough to cause engine damage.
Old Oct 15, 2006 | 06:52 PM
can you elaborate on what you mean by air flow pattern?
do you mean at mid range it will flow this much in complement to the fuel/ignition timing
and at different rpms it will flow different from the stock air box, in complement to the fuel/ignition maps?
Also if technecly you run a bit leaner wouldnt it be better, because a stock evo runs pretty rich up top?
Old Oct 16, 2006 | 06:23 AM
jcsbanks's Avatar
Running leaner will probably kill the torque at 2500-4000 RPM.
Airflow pattern - the airflow sensor is about in the center of the pipe so only samples from there. Many detailed posts from me and others about the issue in this thread: http://www.lancerregister.com/showth...ht=missing+bhp
Old Oct 16, 2006 | 08:10 AM
nj1266's Avatar
I will throw my 2c on this subject. Here is what I observed on an 05 Evo 8 like mine, but running an open element Apexi filter. Both cars have a TBE. The car with the open filter has been slightly leaned up top to a 10.4-10.5 AFR, the timing is stock and so is the boost. My car is fully tuned with an 11.3-11.2 AFR tapering to 11.0 by redline and 10.9-10.8 by cuttoff. The boost peaks @ 21-22 psi.
The Apexi filter Evo has a 267 load number @ peak torque/boost and then it falls like a rock. My car with stock filter never peaks @ more than 240-250 and then drops a bit, but not like the other car. The Apexi filter Evo also has IDCs @ 95% while my car is @ 90%.
I suspect that the erratic behavior of the load and higher IDC is related to the Apexi filter element. I have asked the guy to switch back to the stock filter element and come back for a retest. Check out these charts.
Apexi filter Evo
My stock filter Evo
IMHO, the stock box is perfect. Mitsu had to design it that way due to packaging. Messing with it will only cause havoc on the MAF. If you are running below 400 hp, then keep the stock filter box.
Attached Thumbnails Tuning for Intake?-adam_dll.gif   Tuning for Intake?-naji_dll.gif
Old Oct 16, 2006 | 08:33 AM
l2r99gst's Avatar
It would be good to see the boost and AFR logged for your comparison, nj.
The car with the Apex'i filter may have just been spiking to a higher boost level, then dropping, which would explain the higher load.
An AFR plot should show if that is the case or not, too.
John Banks already answered the orignial posted question, so I won't add much to it, but basically an intake may make you run lean because not enough vortices are created at the location where the Karman MAF counts them. The more the airflow pattern is changed, the more the effect. The paper mentioned by John also explains this.
Talking about the Apex'i, though, that filter should straighten the aiflow out relatively well due to the design of the filter. I am interested in more data from your tests, nj.
Eric
Old Oct 16, 2006 | 08:56 AM
nj1266's Avatar
Eric
Eric,
I have the AFR plots for both cars and I will post them when I get a chance. I have the boost plot for my car, but I do not have it for the Apexi filter car. But from what I observed on the car's boost gauge (Defi D) the Apexi filter car's boost behaves no different than the boost on my car when it had stock boost. But I cannot confirm that with hard data. To get boost data from the apexi filter car, I would have had to hack into the stock MAP sensor wire to get a voltage into the GM 3 bar sensor that I use on my car. I do not think the owner would have liked that
Old Oct 16, 2006 | 09:15 AM
l2r99gst's Avatar
I didn't expect you to have the boost log for his car, just saying that it would be good data to see if it was actually a boost spike or bad airflow reading at that point due to the filter.
I don't have any experience with the Apex'i filter, but they do use a good design with a velocity stack, which they call a funnel, to elimnate dead spots and direct the airflow straight into the MAF sensor. I would expect a filter like this one to have less problems than other open element cone filters without a velocity stack.
This picture describes what I am talking about:
Old Oct 16, 2006 | 09:24 AM
awdgsx91's Avatar
100% correct
Old Oct 16, 2006 | 10:06 AM
nvr2fast's Avatar
Indeed I have the Apexi intake, and have not had any problems with it, which I suspect are due to the funnel design you talk about above.
Old Oct 16, 2006 | 03:08 PM
nj1266's Avatar
From what he told me about his boost gauge behavior the car spikes to 22-23 psi and then tapers down to 16-17 psi bt redline. IIRC, that is the same behavior that I had on my car with stock boost and TBE exhaust. I also used a Defi D for a while.
My car also produces a boost spike to 22 psi, but hold boost @ 18-19 to redline since I have boost control. I have tested my Defi D gauge and found it to be about 1-1.5 psi off. So his 22-23 psi is about one psi less. His car might be spiking to 21-22. So the spike in both cars are almost the same, yet the load on his car is much higher than mine and then drops like a rock.
Old Oct 16, 2006 | 04:17 PM
nj1266's Avatar
Here are the AFRs that you asked for Eric. As you can see the low boost/torque AFRs are not that much different on botth cars. The AFR is different above 4500-5000 rpm. I still suspect it is the filter element that is causing the load to spike so high. I guess I will know when I log his car with a stock filter element next time.
Evo w/ apexi filter system
My evo w/stock box.
Attached Thumbnails Tuning for Intake?-adam_evo.gif   Tuning for Intake?-my_evo_afr.gif
Old Oct 16, 2006 | 04:26 PM
jordo's Avatar
My evo w/stock box.
If looking at that.. It looks like the air filter caused it to run richer, which means it is a restriction.. meaning its not making as much power unless it is leaned out.
