Gauges for Evoscan v0.97
Old Feb 11, 2007 | 12:29 PM
  #31
kreionic's Avatar
Bump. Any one else have some good gauge set ups?
Old Feb 11, 2007 | 12:32 PM
  #32
laakness's Avatar
You should check out the forum on Openecu.org. That is where most people have been posting their custom layouts since that is where the developer conducts his discussions.
Old Feb 11, 2007 | 01:55 PM
  #33
kreionic's Avatar
Thanks man I just found one with almost every gauge
Old Feb 11, 2007 | 04:58 PM
  #34
XK120's Avatar
great thread!
Old Mar 26, 2007 | 06:51 PM
  #35
TouringBubble's Avatar
This is what I'm working on ...
It is mainly for "wow," but it is functional as well ... just not as functional as some of the others.
Admittedly, I haven't actually used these gauges since my cable hasn't come in yet. I'll post the XML after I've got them all up and working. I'm being tricky on some of the gauges and stacking scales in order to get the functionality and look that I want. I just hope it works when I plug it in ...
The current measurements include:
Speed
Engine Speed
Wideband AFR
Coolant Temp
TPS %
100% TPS Indicator
Boost (will scale for JDM MAP)
Knock Sum
Knock Indicator
I plan on adding AFR indicators and trying to find a better place for the knock display ... I'm out of room on the factory dash ...
EDIT: I just added the AFR indicators and a speed warning.
The AFR indicators have replaced the non-functional ACD indicators and are set to ...
LEAN - 12.0-16.0
STOICH - 10.0 - 12.0
RICH - 8.0 - 10.0
The speed warning is set at 100 mph and is located at the bottom of the speedometer. If you see this light up yellow, you better hope that nothing lights up blue behind you.
Old Mar 26, 2007 | 09:34 PM
  #36
Here is another ... this one should actually work though =) (Again, i haven't tried it ... my cable should be here in a few days and I can tweak if needed)
The light is set up for an 8k RPM signal and the lights are incremented at 1k. The center lights and "SHIFT" are set at 7500. You should just have to send the Engine Speed signal to the hidden pointer object.
Download the file here (You might need to "Save as ...")
Old Apr 3, 2007 | 04:48 PM
  #37
TTP Engineering's Avatar
Gauges for Evoscan 0.99?
Old Apr 3, 2007 | 05:09 PM
  #38
These work in .99 ... I don't have .97 to test.
Download Left Side
This file includes:
Speedometer (MPH + KM/h)
3-stage Speed Warning Indicator (80, 100, 110)
Tachometer
2-stage STi-styled Shift Light (6k, 7k)
AFR Display (Not Tested)
AFR Indicator Lights (Not Tested)
Download Right Side
This file includes:
Coolant Temp
TPS
TPS Indicator (95% - 100%)
Boost (Not Tested)
Knock Count
Knock Indicator
Load
Timing Advance
Octane
Here is a layout file with many values already assigned.
Enjoy.
Old Apr 3, 2007 | 05:40 PM
  #39
Is that a knock light near the number?
