Are base e_flashes interchangeable.
Old Oct 18, 2006 | 10:38 PM
ant_turbo's Avatar
Can I flash my e_flash in some ones elses evo_9 with the same mods as mines,,,
Old Oct 18, 2006 | 10:40 PM
Ralph's Avatar
Yes. Just change the immobilizer code to theirs.
Old Oct 18, 2006 | 10:48 PM
ant_turbo's Avatar
And where do I find the immobilizer ?? THANKS,,
Old Oct 18, 2006 | 10:50 PM
Kings Fan's Avatar
Are you using ecuflash? You can see it when you load your rom with that program
Old Oct 18, 2006 | 10:51 PM
ant_turbo's Avatar
Ya I am! Is it in ROM INFO ,,,,
Old Oct 18, 2006 | 10:56 PM
inco9nito99's Avatar
Parameters > Misc > 1st or 2nd to last item that shows up. Right-click the data field, click "set data" type in "0x" followed by the immobilizer code. Viola!
Old Oct 18, 2006 | 10:58 PM
Evo_Jay's Avatar
You also have to have the user level on developer.
Also, I dont think the tuner you bought your E-Flash from is gonna like you putting it on other IX's.
Old Oct 18, 2006 | 11:03 PM
ant_turbo's Avatar
Got it guys thanks,,,!!
Old Oct 18, 2006 | 11:06 PM
ant_turbo's Avatar
Ya I know,,,
Old Oct 19, 2006 | 01:51 AM
DynoFlash's Avatar
Not to mention the violation of the "license agreement" contained with the E FLASH!
I tell you - the duesche bag factor is rising high - basically you are talking about stealing someone's hard work
Old Oct 19, 2006 | 02:00 AM
dustin03's Avatar
ture...... But if you don't sign paper work it is not a legal binding contract. you can do what you want with it.
Old Oct 19, 2006 | 02:04 AM
mchuang's Avatar
Do what you want with the map just dont post it here because your eflash is pretty much a removal of boost cut and taper, a raise in timing and a slight lean out of afr which is done without logs so it will probably be way off, and also it offends whomever you got it from. You might as well just take your friends map and make adjustments yourself you will get the same effect.
Old Oct 19, 2006 | 02:07 AM
mchuang's Avatar
If anything you can probably add 3 degrees of timing to entire boost portion and subtract 3 clicks of fuel from entire boost portion and I can guarantee you that you will still feel extra power.
Old Oct 19, 2006 | 08:25 AM
tuffguy's Avatar
Thanks jackass. Way to give them ideas.
An eflash is only $50. How much of a tightass would you have to be to jack a $50 eflash? Oooh, I'll split it with you. You pay $25 and I'll pay $25. Sweet!
Now they're probably gonna raise the prices just to cover themselves for idiots who steal their work. Way to ruin it for everyone.
Old Oct 19, 2006 | 08:43 AM
gsrboi80's Avatar
Just pay for one yourself then you can at least blame the tuner if they blow up your car . Als right these tuners offer these flashes this way as a convinence to us and ask that we keep them to ourselves. For 50 bucks and a tuner having my back in future mods tuning wise Ill take it
