ECUflash v. ECU+ compatability?
Old Nov 4, 2006 | 07:29 PM
MalibuJack's Avatar
As long as the Mitsulogger values for Injector Scale and Injector Latency are left stock (and yours are stock) or you updated them with your upgraded info... Yes the Load calculations are fairly accurate, and should closely represent the load values for tuning the car.
Old Nov 4, 2006 | 07:31 PM
MalibuJack's Avatar
And I can't really say when I plan on releasing V2, it needs alot of work to get the plugin features to do what I want, and I took a break from coding for awhile so I have some fresh insight. I have very limited free time so as things spin down I'll get back into it and crank out some new code.. I also have several other projects that are in development.
Old Nov 4, 2006 | 07:34 PM
MalibuJack's Avatar
the AFRMAP values in the rom (Not sure if this is what you were referring to) are the value in the Map, it doesnt reflect an actual AFR, but what cell the ECU is using. Only its not easy to find the exact value, hence the Load calculation...
In order to tune your car, you MUST be using a wideband O2 sensor to get accurate readings, I am doing it using the ECU+ and its aux wideband input, hooked up my wideband to the ECU+.
SlickDude
Mar 11, 2016 04:37 PM
mcgarvey
Lancer Tranny/Drivetrain Tech
Jan 5, 2016 05:29 PM
Evo Pete MTL
Lancer Engine Management / Tuning Forums
Nov 29, 2012 06:08 AM
Kalivar
12
Oct 19, 2012 07:07 PM
honfui
Mar 9, 2007 02:07 AM
