Some advice with knock and adjustment [pics]
Old Nov 3, 2006 | 01:50 PM
SophieSleeps's Avatar
A friend of mine self-tuned his car and I datalogged it for him and got some interesting results.
I have a datalog included below of what I consider the pertinent info.
I have a pic of his fuel and timing maps (high octane)
I'm curious to see what y'all would do to change his tune.
Since he doesn't have a wideband, my initial thoughts are to decriment his fuel values at the LoadCalc values where there is knock.
And then to retard some timing (decriment values) as a safeguard.
Suggestions?
Old Nov 3, 2006 | 02:34 PM
evo ippo's Avatar
maybe some where it is knocking above 5 retard the timing alittle!?
Old Nov 3, 2006 | 02:44 PM
Ralph's Avatar
Show us the narrowband o2's to see if thats the culprit for the knock.
Old Nov 3, 2006 | 02:45 PM
Was that a guess?
Err. What I'm looking for is just confirmation really...that my thinking is correct.
I'd find knock. Look to see the loadCalc and RPM.
Go to that part of the fuel or timing map and make adjustments.
Old Nov 3, 2006 | 02:48 PM
Ralph's Avatar
Timing Changes I would do ..
7000/180 - 16
7500/180 - 16
11000/180 - 16
7000/200 - 14
AFR, dunno cause can't tell what kind of AFR's you're running..
Old Nov 3, 2006 | 02:51 PM
Ralph's Avatar
Originally Posted by SophieSleeps
Was that a guess?
Yes, do that.
And even if you're not in a certain load cell, it does effect your timing.
7000/180 = 17 degrees
7000/200 = 15 degrees
7000/220 = 14 degrees
The closer your 200~load cell goes to lower 200's your timing will be higher than if you're near 218 load - where it'll be lower as it transitions to 14 degrees.
Old Nov 3, 2006 | 02:56 PM
-=SPECTRE=-'s Avatar
the infamous 6800rpm knock, i have the same thing. after a lot of testing i'm pretty confident that it's phantom knock - but it's still hurting performance.
Old Nov 3, 2006 | 03:01 PM
Ralph's Avatar
No knock 6800rpmish :O
Old Nov 3, 2006 | 03:07 PM
Can you explain your thinking?
I don't have a clue why I'd look at narrowband 02 readings.
Old Nov 3, 2006 | 03:10 PM
you're also running super rich - 10.5:1 at 6200rpm? what are your IDCs like?
Old Nov 3, 2006 | 03:12 PM
Ralph's Avatar
You have no wideband so.. something is better than nothing.
O2 value of .89 is definitely leaner than .92. You seem to lean out at 6593 RPM.. just a instant before you crack 7 knocksum. Maybe you should add some fuel there.. make it read at LEAST .9165, maybe richer.
Narrowband O2 is not accurate but try it out and see if your knocksum lessens.
7000/180 - 16
7500/180 - 16
11000/180 - 16
6500/200 - 14
I can see the reasoning behind the changes you've suggested.
Except for the 6500/200 -14
Currently 6500/200 is at 15 degrees of advance and he gets 2 and 3 counts of knock right around there.
By the way, your response is much appreciated. I'm learning a lot.
Old Nov 3, 2006 | 03:13 PM
Ralph's Avatar
That run wasn't that good, 99%~. Tis why my fuel pump is being installed tomorrow
Old Nov 3, 2006 | 03:15 PM
Ahh. I see. You're trying to gauge the AF from the narrowband.
Yeah I suggested for him to get a wideband in there ASAP.
In the meantime, we may make richening adjustments asap.
I'm trying to finger out how much of a change will correspond to what sort of change in AF.
So if I go from a value of 9.0 (Af = 11.5) to 8.9, what sort of changes in AF will I be expecting?
Old Nov 3, 2006 | 03:16 PM
Ralph's Avatar
I meant to type 7000/200 change to 14.
My bad, typo.
