Anyone can help me out with e Evo 8 Map???
Old Nov 7, 2006 | 10:26 AM
HKSevolutionNYC's Avatar
Anyone can help me out with an Evo 8 Map???
looking to see if somebody can lend me a flash for these mods, i have one from dyno flash for these mods but the ones with * i just added and was wondering if somebody is runnin this setup and can lend me there flash.
3" TBE
ARC Intake
MBC
UIP with HKS SQV VTA
LICP
Walbro 255 FP
Buddy Club 264 Intake Cam **
Buddy Club 272 Exhaust Cam **
Ebay o2 Housing **
ARP Headstuds
SMC Alcohol Injection **
Old Nov 7, 2006 | 06:39 PM
AlwaysinBoost's Avatar
lend you a flash... haha thats funny, are you going to give it back when your done with it?
Old Nov 7, 2006 | 06:45 PM
hondafan's Avatar
i'll tell ya where you can purchase one cheap. www.jestrtuning.com, $50 for an M1 eflash. awesome tuner and at an awesome price.
Old Nov 7, 2006 | 06:53 PM
gsrboi80's Avatar
Honestly with the Allky you should get it custom tuned
Old Nov 7, 2006 | 08:34 PM
hondafan's Avatar
true^. that's a very good point.
Old Nov 8, 2006 | 11:21 AM
it is getting tune by Sean Ivey at Ivey Tune, but im not rich to have all the money to tune it right after i install my cams n studs. gota wait maybe 1 or 2 weeks be4 i can tune it. was wondering if anyone has this setup with a base tune
Old Nov 8, 2006 | 11:28 AM
gsrboi80's Avatar
Got ya. I wouldnt run the allky untill the custom tune. You can get an EFlash for the cams though it wont be perfect but it should get them to idle ok and still make good power
Old Nov 8, 2006 | 04:36 PM
Mad_SB's Avatar
I take it you don't have a wideband o2 sensor yet? The cams will probably cause you to lean out, mine did. with 272's at -2i -1e i got about .3 - .5 leaner depending on the rpm and load.
If you already have a tactrix cable, dl Malibu Jacks mitsu logger from aktive matrix and tune it yourself, of course you kinda need the wideband to do that.
Old Nov 9, 2006 | 08:13 AM
already have the wideband and an EGT gauge. and i have the tactrix cable also. that logger is able to read off a AEM UEGO wideband? thats wat i have.
Old Nov 9, 2006 | 09:22 AM
Mad_SB's Avatar
Sounds like you have everything you need, If it were me, I would tune it myself without the alky, then go see a pro for the alky tune.
borrowing a tune will require you to fine tune anyway so you may as well dive in. Turn the boost down a little, log some runs (keeping an eye on the wideband of course), tune for the load you are getting at that boost level, turn up the boost a little, log some more, fine tune for the higher load. rinse and repeat.
Old Nov 14, 2006 | 08:08 PM
evo_08's Avatar
just have sean make u 2 maps
Old Nov 14, 2006 | 09:29 PM
Ultimate CC's Avatar
I maybe able to help you out when I install your alky kit this saturday. I am currently working on an ecuflash map for my evo with similar mods...
