Evoscan help please...
Old Nov 12, 2006 | 06:03 PM
EVOL EDO's Avatar
did you try making it com1 and com2?
can you get info normally from your wideband using the serial cable and not using evoscan?
im using the iogear guc232a had it for about 4 years now no problems
Old Nov 12, 2006 | 06:12 PM
bigric09's Avatar
i dont have software to pull info from my wideband... not that i know of anyway. or a way to read it other then the gauge face itself. on the UEGO i have, there are 2 harnesses... 1 goes from the 02 sensor it comes with to the gauge and then the other goes to power, ground, then has a blue wire and white one... the blue wire says it goes to a serial adapter if used, and the white one, i forget where... but its not used either....
how are you switching the log to com 1? if i change the block on the devices to anything other then FTDI FT232, the program wont log any info. ... is there something else i am missing ?
Old Nov 12, 2006 | 10:03 PM
EVOL EDO's Avatar
i meant change it so your adaptor shows up as the com1 or com2 port instead of com4 or com5. then make sure your evoscan is logging off that port. i made my tactrix cable com1 and my usb to serial com2 so then when i open evoscan i just select my wideband and set evoscan to read the wideband on com2.
Old Nov 13, 2006 | 05:13 AM
bigric09's Avatar
its not allowing me to change my tactrix cable to com anything, not that i know of anyway, i swear i looked. it shows up as openport mitsu 1.3 or something like that, and when i clicked on properties, there was no port options.
Old Nov 13, 2006 | 09:29 AM
EVOL EDO's Avatar
go to your device manager, it will tell you what com port everything is on next to the device. you can double click on a device to open the device properties. then go to port settings, advanced and you can change what com port its on. you will have to do some reorganizing since the communications port is automatically com 1 i changed my communications port to com4 and put my open port ecu as com1 then set my zeitronix to com2.
Old Nov 13, 2006 | 06:23 PM
bigric09's Avatar
i wonder if something is up with the uego then, i wouldnt think that would make a difference... but i will try it out and see what happens.... it cant hurt
Old Nov 13, 2006 | 06:30 PM
bigric09's Avatar
ive got a question...is there a way to list what is using what comport ?
Old Nov 14, 2006 | 11:15 PM
EVOL EDO's Avatar
when you check the ports in the device manager each device should have the port it is occupying next to it in parenthesis
Old Nov 27, 2006 | 05:03 PM
Lasersleeper's Avatar
Ive been searching for hours to find an answer to this and man I dont even have the software yet. I cant believe there isn't more on this topic. Bigric you gotta be going nutz!
Old Nov 28, 2006 | 09:39 AM
bigric09's Avatar
LOL, you have no idea.... especially since im trying to start selling these cables but want to confirm mine works. I think its something with the UEGO... i am going to call AEM next time i get a chance
Old Nov 28, 2006 | 10:16 AM
MalibuJack's Avatar
Its because the port settings show up in a different place than the openport 1.3 cable shows up under devices. It should be under ports, if the driver is installed correctly, you should see a port specifically associated with it, and a com port number in parentheses..
Also be sure your cable is plugged in when your trying to look for the info.. Not that your doing that, but its a common error..
Old Nov 28, 2006 | 12:44 PM
bigric09's Avatar
yeah, my process is pretty standard now... i turn on the car, plug in my O2 cable, it finds the adapter, i see the adapter in my hardware list... it actually shows up 2 times... one is the adapter and the other says virtual serial port. Neither have a com port in parenthesis or a way for me to set one. This is being such a pain in the ****. i have a very strong computer background, have been repairing them (hardware and software) for the better part of my army career... just cant seem to figure this out. i'm still waiting for someone with a 6 in 1 uego to chime in to see if theirs is working and able to do logs
Jack i know you are super busy and thanks for the help, i just wish it was something so simple lol
Old Nov 28, 2006 | 02:29 PM
MalibuJack's Avatar
This may sound odd, but it sounds like older drivers.. I had a hell of a time getting rid of the old drivers on one of my machines..
Another thought, because I recall another member saying he had this issue, but is your USB-Serial converter for the other devices an FTDI chip device also? I don't have one so I am not sure if this would be a conflict, but its possible..
Old Nov 29, 2006 | 11:46 AM
bigric09's Avatar
when i bought the adapter, it didnt come with adapters... so i had to go to the site and download newest version, I dont have any other devices using a serial to usb converter... the only thing i have ever attempted to install with it is the wideband. I bought it new from best buy, and then installed it. All so far has been a pain in my rear
Old Nov 29, 2006 | 12:19 PM
RazorLab's Avatar
Alot of these adapter I have found don't work very well or a PITA to set up like you are finding out.
This USB to Serial converter I have found works great the first time: http://pfranc.com/usb/usb.shtml
