Evoscan help please...
Old Nov 9, 2006 | 10:37 AM
bigric09's Avatar
Is anyone logging their A/F's using evoscan, an aem uego and serial cable ? I am making cables to go from the UEGO to my laptop... i have a serial to usb adapter, have the drivers, it recognizes it but i dont know what com port it is using for it or where to tell the computer what com port i want that serial device to use.... any help guys ?
Old Nov 9, 2006 | 10:44 AM
Warrtalon's Avatar
Be sure to check and ask in the EcuFlash forum. It is a very good question that will be important to many of us, myself included.
Old Nov 9, 2006 | 10:57 AM
bigric09's Avatar
i have been warr... thats why i posted in evo general so everyone else can see since not many people go in there and they dont hit the main page as current topics
Old Nov 9, 2006 | 10:59 AM
Warrtalon's Avatar
That's true, but the people who would know are the ones who frequent that forum. You may get lucky out here, but it is definitely a new thing. I also have an AEM UEGO about to be installed and would love to use it through EvoScan.
Old Nov 9, 2006 | 11:06 AM
bigric09's Avatar
i am making cables for 25 shipped if you want one ... i posted a thread.... just trying to get the wideband to talk to my laptop stinks.... it sees it because as soon as i plug in the usb it recognizes something is there... so who knows
Old Nov 9, 2006 | 11:19 AM
dudical26's Avatar
if you go to deivce manager you can go to USB and see what port the adapter is using.
Old Nov 9, 2006 | 11:28 AM
bigric09's Avatar
its not there... or at least it isnt showing like it should... i see about 5 usb hubs, the openport mitsu, a mass storage controller, my 5 in 1 card reader and nothing else that i can tell....
Old Nov 9, 2006 | 11:48 AM
justchil's Avatar
There are only 6 to choose from on my evoscan but normally uses 5 or 6. I don't have it installed but you select the port from one of the main drop downs at the top.
Old Nov 9, 2006 | 05:19 PM
evo4mad's Avatar
All wideband serial loggers work with EvoScan... Check the factory wideband logger software if you have problems, most likely just incompatable serial to usb adapters if you do have problems.
Old Nov 12, 2006 | 02:52 PM
bigric09's Avatar
i tried com 5, evoscan takes the scan but isnt logging the wideband... its starting to really **** me off... does anyone have any ideas ? is there anyone out there using this function in evoscan ? im really hoping malibu comes in here for some help.... thanks guys for any help
Old Nov 12, 2006 | 04:03 PM
evo4mad's Avatar
can you try com port 1? that has worked for many before. do you have a proper com port or just an adapter?
Old Nov 12, 2006 | 04:08 PM
EVOL EDO's Avatar
i changed my evoscan cable to be com1, and i changed my usb to serial adaptor to be com2 in the device manager, then in evoscan i set the wideband to read com2 and it worked.
Old Nov 12, 2006 | 05:12 PM
bigric09's Avatar
i will see what i can do... what adapter are you guys using if you dont mind me askin ? im using one i bought at best buy and i dont think it is the problem on its own, im sure its my setup as far as evoscan and my computer go... ill have to see what i can figure out, but any other help will be appreciated
Old Nov 12, 2006 | 05:27 PM
bigric09's Avatar
im sitting in my car now... my comport for the adapter is com2 the virtual serial port is 5 which is what i figure i am suppose to be using... its still not showing anything in the values column when i attempt to log .... just to verify some info :
blue wire from the uego harness goes to the serial cable as well as a ground... i know its pins 2 and 5, dont remember which was which off hand but im sure i wired them correctly... did you guys do anything with the white wire that was there ? and did you guys use that blue ? im pretty sure you did, but this is so stupid now that i need some confirmation... thanks
as far as port settings ... you guys leaving them alone ? 9600 ? and the column that it should be reading is the one that says wideband and is WDB for the abbreviation ... excuse me for all the stupid little questions, just frustrated with this not working.
JUST TO CLARIFY.... YOU GUYS ARE USING THE UEGO THAT INCLUDES THE 02 SENSOR ? NOT THE OTHER ONE THAT IS SOLD
Old Nov 12, 2006 | 06:01 PM
bigric09's Avatar
bump...come on guys, i really would like to get this tackled by tomorrow so i can start logging my a/f's
