problem reading ecu with ecuflash
Old Nov 26, 2006 | 02:19 PM
boony's Avatar
MalibuJack: I've emailed Colby, hopefully he can shed some light. Thanks for the help.
3gt: I've used a friends ODBII lead without any probs - it's not a USB one, just refular serial port. But I don't think there's anything wrong with the harness etc - i'm convinced it's the USB drivers playing up. Thanks for the help.
Please could someone tell me, if you run up ECUFlash with a 1.3M cable attached to the PC but not to a vehicle, what does ECUFlash report the cable as? Is it a "FT232R USB UART A3001LCw" or is it reported as "OpenPort 1.3".
Not sure how ECUFlash recognises it, but I think it's this step that's failing for me for some reason.
Old Nov 26, 2006 | 02:23 PM
boony's Avatar
Burgers, I'm the other end of the country. North-East - near Whitby.
If I don't have any joy in the next couple of days, any chance you'd be able to test my cable if i post it down to you - i'll pay all return postage costs of course, just be nice to prove the cable is working or not.
It's a real pain when something like this happens the first time you try. I don't know for sure whether it's the cable/car/software install or a mixture of all 3 so it's a matter of elimination.
Old Nov 26, 2006 | 04:00 PM
MalibuJack's Avatar
It should be reported as an Openport 1.3 or Openport 1.3 Mitsubishi
If its reported as the OEM chip ID, then it might not have had its settings correctly flashed into it, or it is having a different type of problem.
Old Nov 26, 2006 | 04:10 PM
EVOL EDO's Avatar
did you try manually picking the drivers to make sure it is using the correct drivers?
Old Nov 26, 2006 | 05:56 PM
colby's Avatar
Yes - this is definitely a cable problem - I'll take care of it offline.
Colby
Old Nov 27, 2006 | 05:11 AM
boony's Avatar
Thanks to all for the help and ultimately to Colby for confirming the problem lies with the cable. I look forward to hearing from you.
Old Nov 27, 2006 | 07:28 AM
burgers22's Avatar
Hi boony
Glad to see you look to have got it sorted. If you need cable conformation in the future, let me know.
MB
Old Nov 30, 2006 | 01:28 PM
boony's Avatar
I received some software off Colby this morning that he wrote especially to allow me to flash the cable at my end. Worked a treat and have now successfully read the map from my car!
Many thanks to all who helped, and a big thumbs up for Colby. Cheers!
monkeyevo
Aug 2, 2011 01:52 PM
sweeney87
Apr 9, 2011 02:26 PM
shawn_090
Mar 23, 2011 01:38 PM
Srt4...
Mar 23, 2010 10:05 AM
andber
May 13, 2007 03:47 PM
