Boost too high?
Old Nov 30, 2006 | 02:32 PM
boony's Avatar
Boost too high?
Hi
Just had my zeitronix zt-2 installed today, did a 4th gear pull on the way home and the boost peak was >23 psi.
Car is a standard JDM VIII MR (UK FQ-300). The map is totally standard (read from ECU tonight with ECUFlash) so the boost limit hasn't been touched.
As I understand it, the car should hit the fuel cut @ 1.2 bar, but it doesn't.
Could this be a dodgy reading from the zt-2 or am I missing somthing?
Cheers,
Boon
Old Nov 30, 2006 | 02:36 PM
Jeff_Jeske's Avatar
What does the boost read in 3rd gear?
My car tends to increase boost with increased load. I see higher boost in 4th and 5th gear. I see higher boost going up hill too.
Old Nov 30, 2006 | 02:48 PM
boony's Avatar
Thanks for the reply, it's reassuring to know I'm not alone :-)
Don't know what the boost hit in 3rd gear, but the 4th gear pull was up a hill too.
Tomorrow night, I plan to do some logging to get a better idea. I'll log each gear I think and have a proper look.
Old Nov 30, 2006 | 02:53 PM
4WS Tuning's Avatar
if everthing is premapped.. im sure its fine.. tons of engineering is put into those FQ cars.
i would log all the gears like ya said you plan on doing and look out for knock. no knock, no problem.. i have a few friends that run that much boost on 93. i run 22 pounds and i could run 23 if i wanted to, but i would perfer to have a wideband to tune for that
cheers!
Apex Hunter
Sep 15, 2015 10:21 AM
Ghost1t
Feb 7, 2011 12:51 AM
SOEX
Oct 10, 2008 12:28 PM
EVO8LTW
May 30, 2008 07:30 PM
500whp.com
40
May 18, 2006 10:29 AM
