How-to flash your ECU using ECUFLASH
Old Apr 7, 2007 | 03:05 PM
  #61
TouringBubble's Avatar
Originally Posted by bhamEVOguy
do u have to take datalogs to get the flash?
if yes, do u need a different software for that or does the ecuflash software has this feature.
ECUFlash does not support logging. Mitsulogger and EvoScan are both great apps that can take care of it though.
Old Apr 9, 2007 | 08:17 PM
  #62
bhamEVOguy's Avatar
sorry for the misunderstanding, but my question was, do u have to have the logs in order to get a flash. is it required? its kinda confusing. the site says,required for the updated images. that would mean that u need it if u r getting a flash 2nd time?
Old Apr 10, 2007 | 09:50 AM
  #63
4g63_guy's Avatar
you do need logs to properly flash the ecu. how else would you know what you'll be tuning. I remember with my old dsm and dsmlink I would do a few pulls and log it and pull over review the file and adjust fuel trims and or pull off or add timing. it's a little time consuming, but the way most people would have to tune.
Old Apr 12, 2007 | 04:42 AM
  #64
hksevoix's Avatar
whoa overwhelming information, can someone quickly sparknote these steps preferably in a list on how to completely do this process????? ex: buy tatrix cable, dl ecuflash, get this do that... because the tutorial was not completed as I noticed you have to change user option to developer? and then logging information? plus
Datalogs (ie: pocketlogger, Zeitronix, Logworks, etc.) **Required for updated images**
don't understand this ^ |process plz, thanks!
Old Apr 12, 2007 | 12:26 PM
  #65
bhamEVOguy's Avatar
^^^ i was confused on the same thing. emailed jestrtuning n this is what they said
"No, I will need datalogs after the initial flash. Then updated images will be provided after those logs are ananlyzed."
u need to take datalogs only if wanna get flashed a second time.
hope that helps
Old Apr 12, 2007 | 01:40 PM
  #66
hksevoix's Avatar
so sending logs with like mitsulogger ect.. is only requre for the m2 flash? or is it require after the m1 as progress purposes?
Old Apr 14, 2007 | 08:27 PM
  #67
codgi's Avatar
Logs aren't required for any flash. They just help the tuner adjust the initial flash to work correctly with your car. Some tuners request them up front since it will help them dial in the tune better from day one.
Old Apr 24, 2007 | 09:32 PM
  #68
evolrobert's Avatar
awsome
Old Apr 27, 2007 | 01:16 PM
  #69
Q8_EVO's Avatar
I just recieved my Jester Image.. I am going to upload it tonight..
what happens if i dont remove the Pill?
i dont have time to do it now
will my car run ok ? with or without the pill removed
Old May 2, 2007 | 01:01 AM
  #70
cooliodb's Avatar
Nice video. I am a newbie to ECUFlash and appreciate all the good info.
Old May 8, 2007 | 08:46 AM
  #71
Chemwarrior's Avatar
Bump for a response to this question. I was wondering the same thing.
Old May 8, 2007 | 08:48 AM
  #72
MalibuJack's Avatar
You should be directing this to the Vendor/Tuner.. We can't answer this with certainty.
Old May 8, 2007 | 08:50 AM
  #73
Mellon Racing's Avatar
whoa overwhelming information, can someone quickly sparknote these steps preferably in a list on how to completely do this process????? ex: buy tatrix cable, dl ecuflash, get this do that... because the tutorial was not completed as I noticed you have to change user option to developer? and then logging information? plus don't understand this ^ |process plz, thanks!
I have a list of resources for downloading and buying the ECUflash, tactrix cable, evoscan and mitsu logger etc.. and I also explain how the tuning process works - see sig
Old May 27, 2007 | 07:37 AM
  #74
warp9's Avatar
Nice write guys, thanks a bunch!
Old Jun 28, 2007 | 09:34 AM
  #75
EVO8emUp's Avatar
Bump for the newbs.
