WHAT RPM IS YOUR 2 Step LAUNCH SET AT?
Old Dec 5, 2006 | 10:43 AM
  #31
Ultimate CC's Avatar
anywhere from 18psi up to 25psi depending on the day...
Old Dec 5, 2006 | 10:57 AM
  #32
Soon2BEVO's Avatar
God damn. No wonder I was spinning into 2nd
Old Dec 5, 2006 | 11:20 AM
  #33
20psiMR's Avatar
Spinning is better then blowing a tcase, that power has to go somewhere hehe. A little spin is good, too much spin and your blowing your 60' times. Try lowering your launch control some, or get a shep tcase.
Mines at 5900, stock clutch IX 6 speed. I dropped it a touch from 6k and noticed I can cut consistent 1.7's with full tire pressure. Just pull your foot off the clutch as fast as you can, tires will squeel a touch and she MOVES. Best 60' so far is 1.72 and it doesnt feel like Im killing the car since the tires still squeel a bit.
Old Dec 5, 2006 | 01:24 PM
  #34
hondafan's Avatar
man, it scares me to just dump the clutch without the restrictor in the line! i always slip it a tad.
Old Dec 5, 2006 | 01:28 PM
  #35
4Gsixty3's Avatar
5500rpm
  #36
i still have my restrictor in place...
Old Dec 5, 2006 | 01:36 PM
  #37
20psiMR's Avatar
I still have restrictor too. Actually from what Ive heard, its not a good thing to remove. Id rather let it slip the clutch a tad then blow up my tranny.
  #38
saiyanzzrage's Avatar
6000
Old Dec 5, 2006 | 01:37 PM
  #39
mac_05evo's Avatar
Last time I was at the track, I was getting lots of wheel hop coming out of the whole, which I know is very bad and I lifted immediately.. I was launching anywhere from about 5600-5800 with a method like 20psiMR described above, quick coming off of clutch.. Anyhow, I had one decent pass where I cut a 1.74 60' time w/ just some slight spinning, next pass I cut a 1.73 60' time after letting off because of wheel hop..
Anyways onto my question.. Is it my launch method, tires, track prep, etc. that is more than likely causing this wheel hop?
BTW my 2 step is at 6k but have always used the method I stated earlier..
Old Dec 5, 2006 | 01:46 PM
  #40
Smike's Avatar
5000. Yes stock 5000. 1.61 60s.
Old Dec 5, 2006 | 02:18 PM
  #41
Evo_Jay's Avatar
Yeah, on my VIII, I removed the restrictor and added the SS line. But everytime I would launch, I would be scaried to drop it too fast, and inturn would drop it too slow, burn the clutch and get terrible 60ft times (+2.0).
With my IX, I left the restrictor and OEM line. Now Im not scaried to drop it really fast, and I get better 60ft times (1.8 consitently).
Old Dec 5, 2006 | 02:42 PM
  #42
Xfer's Avatar
6200...I don't launch anymore cuz I didn't lift fast enough the first time and burned the clutch pretty bad. Still very drivable but noticeable engagement difference.
Old Dec 5, 2006 | 02:57 PM
  #43
d'shark's Avatar
6000 with consistent mid 1.7 60'. stock clutch, starting to slip. 15,000 plus miles
Old Dec 5, 2006 | 07:05 PM
  #44
laramie_05MR's Avatar
5k with stock clutch. 1.8 60'. 29k miles
Old Dec 5, 2006 | 07:13 PM
  #45
mac_05evo's Avatar
Anyone know? bump..
