ECUFlash / Evoscan / Mitsulogger Questions
Need some help with openport
Guys please I need some help I have looked every where and unable to source out installation step by step guide on making this thing work. I have looked every where can anyone help me please.
1st of all I have managed to install the drivers for the openport cable.
2nd I both have evo-scan and also EcuFlash on my laptop. But can’t get it connected.
3rd of all when I plug in my cable all my diff lights flash and also my computer light.
Can some one please help??????????
Also another thing this cable that I have purchased lets you fine tune your car right?
So just say for instance if I give it to some one to Dyno tune my car they can do it with Ecu Flash?
Because I took it my tuner and he was laughing at me when I told him that it could be done and also I want to get the last laugh
Also does this openport cable work Evolution GT-A
My logger v6 is not showing boost past 25psi...it just shows negative. My zt2 display unit clearly shows it, however, the logs just don't show the full numbers...log below. I am boosting 27psi.
Code:
RPM A/F MAP KS 3500 12.1 13.2 0 3593 12.1 15.2 0 3687 12.1 17.9 0 3781 12.3 20.9 0 3906 11.8 23.8 0 4000 11.4 25.5 0 4125 11.5 -1 0 4281 11.6 -0.9 0 4437 11.6 -1.1 0 4562 11.6 -1.3 0 4687 11.5 -1.3 1 4843 11.6 -1.3 1 4968 11.6 -1.2 1 5093 11.6 -1.3 1 5187 11.6 -1.3 0 5343 11.6 -1.2 0 5468 11.7 -0.8 0 5593 11.7 -0.7 0 5750 11.6 -0.4 0 5843 11.5 -0.4 0 5968 11.5 -0.4 0 6062 11.5 -0.5 0 6187 11.6 -0.2 0 6281 11.6 25.5 0 6406 11.6 25.3 0 6531 11.5 24.9 0 6625 11.4 24.7 0 6718 11.2 24.4 0 6781 11.1 24.1 0 6906 11.1 24.1 0 6968 11.1 24.2 0 7062 11.2 23.9 0 7125 11.2 23.2 0
Jack,
I am attempting to use Mitsulogger to log both data from the ECU and from a UTEC. Here is the error I am recieving. Is there something I am doing wrong? I can see the UTEC data being logged in the debug window, and the logger works fine when only logging information from the ECU.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at MitsuLogger.x751922eb1bfae5fb.x9019a79b966d57d0(Ob ject xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndPr oc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.832 (QFE.050727-8300)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MitsuLogger
Assembly Version: 1.6.2640.35940
Win32 Version: 1.6.2640.35940
CodeBase: file:///C:/Documents%20and%20Settings/Todd%20Zimmerman/My%20Documents/Evo%20VIII/Mitsulogger%20v1%5B1%5D.6%20Beta%203/Mitsulogger%20v1.6%20Beta%203/MitsuLogger.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
AxInterop.MSScriptControl
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Documents%20and%20Settings/Todd%20Zimmerman/My%20Documents/Evo%20VIII/Mitsulogger%20v1%5B1%5D.6%20Beta%203/Mitsulogger%20v1.6%20Beta%203/AxInterop.MSScriptControl.DLL
CodeBase: file:///C:/Documents%20and%20Settings/Todd%20Zimmerman/My%20Documents/Evo%20VIII/Mitsulogger%20v1%5B1%5D.6%20Beta%203/Mitsulogger%20v1.6%20Beta%203/Interop.MSScriptControl.DLL
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
mscorlib
MitsuLogger
System
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
Code:
You ever have any luck with this? I've been using evoscan 0.99 due to this problem... I can't get 1.0 to work with my zt2 at all... I just get 0's in my logs.
Here is a good one ...
What does the temperature compensation table actually do? Does it skew fueling, timing, load, airflow? I've adjusted it successfully, but I don't know if anyone really knows what it does.
the negative number thing in Mitsulogger was an integer error, values over a certain point would show as negative.. I never tested over 25psi (because I didn't have the ZT2 installed in a car when I wrote the software)
It was fixed in later maintainence versions of Mitsulogger that were never released due to my work on the v2.0 version of mitsulogger is a complete rewrite.
Malibujack,
I tried to installed the InstallInnovate file to get my LC-1 to work with mitsulogger, but I keep getting an error after a dos-prompt window comes up, the error message comes up and thats as far as it goes, I've attached an image of what the error message is...any suggestions on what I'm doing wrong?
Thanks
Thanks
Thats a vista specific error, you need to open the command prompt with administrator rights and manually register it. It took me almost a day to figure out why that was happening.
