ECUFlash / Evoscan / Mitsulogger Questions
Old Aug 7, 2009 | 12:24 AM
  #631
YaroRS's Avatar
guys, I have probably a realy stupid question. Today I tried to open periphery bits in ecuflash and it doesnt show full number or area, how can I enlarge the area it shows ?
Attached Thumbnails ECUFlash / Evoscan / Mitsulogger Questions-stupid-question.png
Old Aug 11, 2009 | 08:13 AM
  #632
QwikEVO's Avatar
How do I switch rom ID's?
I have an 03. I need to go from 94170008 to 94170015
Old Aug 16, 2009 | 01:40 AM
  #633
leecavturbo's Avatar
Playback of logs in evoscan is slow and jerky?
Old Aug 16, 2009 | 06:56 AM
  #634
3gEclipseTurbo's Avatar
when i log with mitsulogger it doesnt log my fuel trims. how do i fix this?
Old Aug 16, 2009 | 11:46 AM
  #635
2.6 full version logs wideband as knock and vice versa
Old Aug 17, 2009 | 09:38 AM
  #636
2.0Ldoom's Avatar
Hey guys dumb question im new to logging so, I have Evoscan and an AEM UEGO, I want to log the a/f but not sure how to hook it up to my laptop...Stock ecu
Old Aug 17, 2009 | 01:00 PM
  #637
x2 but with mitsulogger
Old Aug 19, 2009 | 08:15 AM
  #638
Jhutterer's Avatar
EvoScan not seeing COM port 12
I am using an Innovate LC-1 and trying to log over the serial out through a Keyspan USA-19HS. My computer is assigning COM port 12 and the software(logworks) from innovate can log from the device but I can't get EvoScan v2.6b to see COM port 12, it only can see COM ports 1-7.
One thing that does happen when I unplug the Keyspan device COM port 1 and 2 disappear. I have tried to log from both ports through Evoscan using the External Wideband A/F Ratio selection, but the function column has an x in it so of course I get 0 throughout the log.
I don't know if I am supplying enough information or not but I can't figure out why it won't log in evoscan.
Any help would be greatly appreciated. I did try to search maybe I wan't using the right criteria but I couldn't find anything on this issue.
Old Aug 19, 2009 | 08:23 AM
  #639
browningderek's Avatar
mitsulogger ??
i can seem to find what im looking for. i searched a few different ways with no luck.
i just downloaded mitsulogger v1.6.... i got it to start and stop logging fine.
my question is how do i play it back? there is no playback button. no graph.
do i need another program to play it back? like dll? please help. thanks guys..
Old Aug 22, 2009 | 03:23 PM
  #640
cs82685's Avatar
After searching, I got nothing so, should the 'clear dtc's' button turn my cel off for obd-II?
And if so, if it is not turning it off, can that have something to do with my cable? I'm not sure what cable I have (I know it's a 1.3, but not positive which version)
As I just learned today, the 1.3d is not capable of reflashing, which would make me think it also wouldn't be able to turn a CEL off
Also while I'm at it, I didn't search for this one, but is there a way to tell which cable I have without trying to write to the ecu?
edit: found a post by hamish and reread the descriptions of the cables on his site, so I know I have 1.3r or 1.3u, just not sure which one
Almost forgot, evoscan won't stay connected when I'm using obd-II (this is on a nt 2g dsm fwiw)
Old Aug 24, 2009 | 09:36 AM
  #641
Jhutterer's Avatar
Bump for help..
Old Aug 25, 2009 | 08:42 AM
  #642
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
Select MUTII EFI instead
Old Aug 25, 2009 | 10:37 AM
  #643
cs82685's Avatar
Forgot to mention the code I was trying to clear was on the same nt eclipse not on the evo which is why I had obd-II selected, are you saying I should still select MUTII?
Old Aug 25, 2009 | 09:55 PM
  #644
acamus's Avatar
Correct.
Old Aug 26, 2009 | 01:20 AM
  #645
03lances's Avatar
Click Here This will tell you all you need to know to log your AEM Wideband
