I only drive in 3rd gear
Old Dec 26, 2006 | 05:48 PM
nj1266's Avatar
Originally Posted by cij911
I like your signature...I hope you are not busting... j/k
My understanding is that the car runs a tad richer in the higher gears because the ECU has more time to respond to load changes...I believe Ivey and/or Jestr posted about this awhile ago....I still think most are running way too rich on this site, but that is a whole different subject.
I'll PM you my AFRs in a week. Good luck
Shiv said the same thing when we were wondering why the AFR on the maps on his website were so lean.
Old Dec 26, 2006 | 05:57 PM
cij911's Avatar
What AFR range does Shiv generally tune?
Old Dec 26, 2006 | 06:10 PM
ries's Avatar
Try tuning in 4th gear....I do my tuning in 4th and car has great AFR's in all gears and no knock
Old Dec 26, 2006 | 06:26 PM
SophieSleeps's Avatar
Originally Posted by razorlab
Have you tried putting the higher load fuel settings to the same as you have them in the load column you are hitting in 3rd gear.
Sometimes evoscan isn't the gospel.
Yeah, I'm not so sure the loadcalc is really all that accurate. That may be part of it.
Look on the bright side, you did not have to buy her a Xmas gift
Eh. It was a 6 year long relationship. I still had to.
Who's Shiv, and why do we trust him? Is there any reasoning behind his explanation? Slow ECU response could be a reason but how realistic is that?
I've seen very slow responding processors like the SAFC and stuff...but definately not factory ECU's.
Originally I tried to do that. Same thing though.
It may be a loadcalc function problem in evoscan though.
Old Dec 27, 2006 | 10:06 AM
AzBlackEvo8's Avatar
This should explain why he *might* just be trustable
Shiv @ http://www.vishnutuning.com/
Old Dec 27, 2006 | 10:27 AM
No it doesn't at all.
I'd rather read the reasoning behind it rather than accept some dude's theory because of his email / web address.
Old Dec 27, 2006 | 12:43 PM
C6C6CH3vo's Avatar
For me 3rd gear is all I'm concerned with, first and second are leaner but the load intensity and duration are much less so everything just just works out with a leaner burn.
As for forth gear - I really never plan to drive WOT at those speeds on public roads anyhow. Once I make it to a 1/4 track however, I'll just have to live with it rich from 90 mph and up while I'm in 4th
Old Dec 27, 2006 | 04:51 PM
burgers22's Avatar
Hi
The changing load theory should be fairly easy to prove, If you equalise all the load cells for a given RPM ( something safe like 11) then the AFR shouldn't change when shiffting up. Mosy mapps are scaled to get richer as the load increases and the ECU will interopulate between load cells.
MB
Old Dec 27, 2006 | 05:39 PM
Evo_Jay's Avatar
This is why you should maybe listen to him...
"Shiv Pathak, established himself as an industry leader in the design and tuning of high performance engine management systems. Having contracted his engine tuning skills to OEMs such as General Motors and Toyota, several professional road race/rally teams, numerous aftermarket tuning houses and hundreds of private individuals, Pathak carries with him a wealth of real world engine management know-how. This unique knowledge lead him to his next vocational area where he continues to freelance as a technical writer (product reviews, technical analysis, long-term project car testing, etc,.) for numerous automotive trade journals. With one foot firmly planted at the leading edge of industry technology and the other standing at the center of aftermarket street and race performance, Pathak has developed a reputation for bringing high-end engine control systems to the masses. Along with that, he has earned a reputation for unwavering customer support and an unblemished track record in the engine management industry."
Old Dec 27, 2006 | 05:43 PM
jamevo8's Avatar
Foot fetish?
Old Dec 28, 2006 | 09:03 AM
Originally Posted by burgers22
Hi
MB
I posted my logs...seeing the same loads at the same RPM's but showing different AF ratios. I'm not so sure your idea will work.
I think it's really a function issue in evoscan at this point.
I'm not the sort of person to take advice on trust. I'd rather get the reasoning or theories supporting that advice. Following someone based on their history may work most of the time, but it doesn't make you any more knowledgeable.
It's my pet peeve. I need to know why and if I can't understand or rationalize it then I have to question it.
A lot of people say things in passing or off the top of their head. That doesn't mean that there is any sort of data to back it up.
But thanks for posting his background. I didn't know who he was.
Old Dec 28, 2006 | 09:25 AM
MalibuJack's Avatar
Your best not taking anything as gospel, as anyone can make mistakes. And learning is all part of the game.
I agree if you can tune in 4th gear, you might have better results..
Calculated load is a "Strange animal" as it seems there are more factors that affect the IPW that can result in reporting a different calculated load than what the car actually is running in.
Look at the load sites, if you tune in 3rd gear, when you tune in 4th, look at one cell to the right, and for second, look at a few cells to the left, and tune those too..
Tuning isn't about isolating specific cells and making adjustment, but the relationship to cells around it too.. This is what allows a tune to maintain a stable AFR.
Also, keep in mind that if your load site is 250, your cell to the left is 230 and to the right is 270, the range from 240-260 is interpolated, if your load is 260 exactly, it'll be the exact number you put in, but if its 245 it'll likely be somewhere in between the adjacent cell, and the current cell.. Same thing with RPM, if your at 6500rpm exactly, it'll be the value, but if its between two cells, it will likely be interpolated..
Old Dec 28, 2006 | 09:28 AM
Thanks for the advice.
Yeah at this point I think I have 3rd gear tuned pretty much as accurate as I can get it.
However, there are limitations in resolution. Tuning in 500rpm blocks and load values every 20 units is difficult. I've learned that you pretty much have to make educated guesses in many surrounding cells in order to get very specific areas to the AF that you'd like.
Anyway, yeah I'll start logging and tuning more in 4th and see what happens. Thanks.
Old Dec 28, 2006 | 09:30 AM
MalibuJack's Avatar
FWIW timing is a little different since we can only make 1 degree steps, and I'm pretty sure the ECU only works in 1 degree steps.
BUT, Timing has a direct affect on AFR also, as more timing means more time for fuel to burn, resulting in a different AFR even though the AFR value in the map is the same at two adjacent cells.
Old Dec 28, 2006 | 09:33 AM
MalibuJack's Avatar
This is why you tune in blocks, and the reason why somtimes you'll find blocks of values..
The values between cells are interpolated if the number isnt an exact hit.. So if the trend is a few points between, then you tune the adjacent cells accordingly to match the "Curve" as close as possible (its likely slightly curved, where an interpolation between both points is linear)
