Considering ECUFlash on my IX
Old Jan 4, 2007 | 02:50 PM
UpstateEVOVIII's Avatar
Originally Posted by 20psiMR
I personally would highly recomend TTP, Jestr, or Sean Ivey in the way of base email flashes. Those guys have it down really well.
Ecuflash supports AEM, and sounds like MJ will have mitsulogger supporting it shortly. Nothing but good things learning how to tune your own car. Just dont go to crazy till you really have a good understanding of what you are doin.
I appreciate the reply and am currently talking to TTP about a setup. Their reputation proceeds them in I read nothing but good reviews on these forums. I will probably go with ECUFlash to start and then switch to "Unilogger" once MJ has it setup for the AEM UEGO. I probably won't change much of anything until I really realize what is happening with the car. Last thing I need is to rush and blow something up
Old Jan 4, 2007 | 03:34 PM
20psiMR's Avatar
Good call, have fun
Old Jan 4, 2007 | 04:45 PM
TTP Engineering's Avatar
Just keep in mind that ECUflash is the reflashing program used to read and write to your ECU. Evoscan and MJLogger/Mitsulogger/Unilogger are dataloggers.
You will always need ECUflash to flash and read your ECU.
Old Jan 5, 2007 | 07:46 AM
Correct. That much I have come to understand. EvoScan for wideband logging w/ the AEM and ECUFlash to flash/read what's going on in the little brain she has. Thank you again for all the help. You have a new pm ttp
Old Jan 5, 2007 | 08:14 AM
EVOScan and ECUFlash downloaded and installed....oooohhhh this is getting exciting
Old Jan 5, 2007 | 09:46 AM
Tactrix cable ordered, too. Weeeeee
Old Jan 5, 2007 | 10:02 AM
Let me know when it comes in and I will walk you through the rest of the process.
Old Jan 5, 2007 | 10:33 AM
PM sent...again :P
Old Jan 5, 2007 | 11:04 AM
Paid
Old Jan 5, 2007 | 11:08 AM
fromWRXtoEVO's Avatar
Originally Posted by AMSTuning.com
Not to speak in too broad of terms, but the Evo 9 responds very well to flashes. Most e-flashes available on this forum, Jestr, Dynoflash, TTP and etc will give you good gains over your base map. If you are a do-it-yourself type of guy - definetly start out with a vendor's map, it will help you understand what values were changed and why - from then on you can start logging and making small changes to see if you can squeeze out a bit more power.
^^^What you said. =+1
Carlos
Old Jan 5, 2007 | 11:21 AM
Can't wait to experiment, very excited to get this all working
