AFR adjustment
Old Feb 6, 2007 | 05:02 AM
  #31
C6C6CH3vo's Avatar
Originally Posted by jcsbanks
The IPW in open loop is based mainly on load which looks up the AFR map and uses injector size to reach a final value.
Using the IPW and RPM you can then calculate the IDC. The injectors won't introduce more fuel once you get beyond about 95% IDC because they have no time to close.
The "real" size of the injector doesn't matter here, it is only the electrical duty cycle of the injector drivers.
So if my AFRMAP A:F value (14.7*128/AFRMAP) is no where near the actual value I have on the map then similarily the IPW value should be wrong too?
What can cause this (AFRMAP value different from map value) anyhow?
Originally Posted by cij911
I am wondering if a real 24 / 25 peak psi and 19 psi @7000 rpm (Zeitronix boost sensor) is too much for 93 and if I'd be better off with 23/24 peak psi and 17/18 psi @7000RPM. Thoughts??
I run less boost than that on Methanol injection
Old Feb 6, 2007 | 05:05 AM
  #32
jcsbanks's Avatar
I believe that the AFRMAP logged value is a post-processed AFR value from the fuel map AFTER lean spool modifications have been applied.
Remember this is active on US cars as well and seems to lean out the mixture 1 AFR approx from the fuel map value until 7000 RPM.
Old Feb 6, 2007 | 05:36 AM
  #33
cij911's Avatar
Do you have a 9? What boost are you running and on what grade fuel?
Old Feb 7, 2007 | 08:35 AM
  #34
jcsbanks's Avatar
I increased my fuel pressure from 3.0 to 3.6 bar by modifying the OEM regulator. I prefer this to a new reg for stealth and reliability.
Now I can run 23-24 PSI (depends on atmospheric pressure mainly it seems) at 6000 RPM with 11 degrees timing at lambda 0.78 with 90% IDC whereas before I was at 100%. I get the odd knock sum of up to 3 or 4 scattered about, usually in the lower gears.
Here is my timing map with the 10% methanol:
http://john824.fotopic.net/p38418308.html
Old Feb 7, 2007 | 07:22 PM
  #35
cij911's Avatar
John -- Very impressive....You are doing a wonderful job with your baby ....BTW, with regard to your airbox modification, have you found that putting the hole on the side of the lid to be beneficial? I have a lid with just the top cut and will be doing back to back comparisons. Thanks for your help.
Old Feb 8, 2007 | 02:41 AM
  #36
jcsbanks's Avatar
Yes I lose only 5-5.5% of atmospheric pressure compared with 9.5-10% on the standard setup. This gain is multiplied up by the turbo giving you about 2 PSI for "free" working the turbo as hard.
Old Feb 8, 2007 | 04:24 AM
  #37
cij911's Avatar
Sorry for my unclear question. I have the lid cut out on the top, but don't have the side cut out. Do you think there is a benefit of having the side open as well as the top ? Someone speculated that the side hole helped flow, but I can't understand why other than more of an open filter. Thanks again.
Old Feb 8, 2007 | 09:12 AM
  #38
jcsbanks's Avatar
The whole lid off would flow slightly better but I feel it would draw too much hot air, hence I did the coldest side I could and stopped when I saw the pressure drop getting near to an induction kit's performance. Result: free and should outperform induction kit in hot conditions.
Old Feb 8, 2007 | 09:14 AM
  #39
cij911's Avatar
Awesome...thanks...
Unrelated topic...I am about to put on an O2 Housing (ebay SS autochrome / Megan Racing) and am wondering whether I should send the part to Swain for coating. Any thoughts on this and/or the exhaust manifold -- is it worth the expense / time to do, or should I just slap the new O2 housing on? Thanks
Old Feb 8, 2007 | 12:09 PM
  #40
jcsbanks's Avatar
I'm getting one and was just going to slap it on. I'm hoping I can get the heatshields back on afterwards.
Old Feb 8, 2007 | 01:46 PM
  #41
RazorLab's Avatar
JCSbanks,
this might interest you:
http://www.norcalevo.net/forum/index...html#msg218992
Old Feb 8, 2007 | 02:04 PM
  #42
jcsbanks's Avatar
Thanks!
Old Feb 8, 2007 | 03:30 PM
  #43
jcsbanks's Avatar
Just spent ages reading NorCalEvo.net
"That" Works thread is "interesting" PMSL.
Shaun@AWDMotorsports
Jun 14, 2016 10:34 AM
awdordie
Apr 30, 2011 09:44 PM
Stradag
Apr 26, 2010 03:49 PM
hediki12
Jan 28, 2010 08:49 PM
SwiftEVO
17
Jun 22, 2005 11:20 AM
