AFRMAP differs from fuel map too much
Old Feb 7, 2007 | 12:15 PM
PVD04's Avatar
Originally Posted by C6C6CH3vo
Wideband for actual AFR
AFRMAP (14.7*128/x) for the actual AFR value the ecu is reading off the map. Supposed to be more accurate than the load calc, but I think it's BS if other people's value is off too - and thats what I'm trying to find out.
Mine never seemed to match. I only checked it once or twice and when it wasn't even close didn't bother checking again. I do wonder how the lean spool enable and disable may affect this.
-Paul
Old Feb 7, 2007 | 12:17 PM
C6C6CH3vo's Avatar
Originally Posted by l2r99gst
What load value in your high octane timing map has a value of 10* for 5500RPM?
240, 260
Thanks
Well, if other people are haveing inconsistancies too, I can finally be at ease and ignore this worthless AFRMAP figure. I was thinking my ROM had scale problems.
Load calc seems to work good for me
Old Feb 7, 2007 | 12:34 PM
l2r99gst's Avatar
240, 260
So, it looks like your AFRMAP may be off by one point then, which may be due to the lean spool.
Your fuel map at 5500 and 240 load is 10.8. Your AFRMAP value comes out to 11.8.
Eric
Old Feb 7, 2007 | 10:30 PM
C6C6CH3vo's Avatar
Does overiding "lean spool" by leaning the map have any drawback compared to deactivating LS alltogether? Like tie up ECU processing
Old Feb 7, 2007 | 10:33 PM
JohnBradley's Avatar
I havent noticed any side effects, negative drawbacks, or anything else wrong from having Lean spool entirely disabled. I also dont log the AFRmap value, I just rely on my WB at all times so I hadnt noticed that this was an issue before. With LS off, for the most part you can simply add a set value to the target value and arrive at your WB reading. I have found that more or less its 1.4 or so, but everyones WB reads a little different.
Old Feb 8, 2007 | 05:10 AM
C6C6CH3vo's Avatar
Thanks, I will be ignoring this AFRMAP thing now
Originally Posted by JohnBradley
I havent noticed any side effects, negative drawbacks, or anything else wrong from having Lean spool entirely disabled. .
Sorry, I meant to say if there is any drawbacks in NOT having the LS disabled, if it adds more demands on the ECU or something.
Old Feb 12, 2007 | 02:52 PM
4WS Tuning's Avatar
Originally Posted by Imyurturboluva
You get free tuning software and free support via this forum and you're still not happy? Dammit man!
lol think about it... it'll happen eventually. ya type the exactly a/f u want and it just happens...
im not familiar with the cobb thing for subaru's but doesn't it do something like that?
Old Jun 24, 2007 | 05:38 AM
Jumperalex's Avatar
what is really annoying is that motorcycles (with a Power Commander ) have had sort of auto tuning for a while. do about 20-30, or even more, dyno passes at different throttle settings, holding RPM at certain points (the computer tells the tuner exactly what to do), and you end up with a complete fuel and timing map tweaked in every cell. too bad my bike is still carb'ed ... damn LAST YEAR they sold the R6 w/o FI.
anyway ... yeah it will happen with cars soon enough since we now have the ability to flash and it is getting bigger. I'm surprised no dyno shop has come up with a system to do it [shrug].
oh yeah and people trade power commander maps like they are baseball cards. of course there is less expertise involved in creating a power commander map since the computer tells the monk .. err mechanic, exactly what to do.
badev0
Sep 15, 2025 03:21 PM
Kwame@Z1
Evo 'For Sale' Wheels / Tires
33
May 6, 2011 09:54 AM
RyuEvoIX
Jan 7, 2011 08:02 AM
mike1023
Mar 10, 2008 06:30 AM
