Understanding load
Old Feb 7, 2007 | 10:22 PM
llabmik2's Avatar
Understanding load
Well coming from tuning with uberdata, and NA cars. This load is new to me. Why is there more then 100% load? I max out at 260 load on ecuflash but when i log i get 310 max load. Should i configure my fuel maps to go that high? Then also im reving to 7800 so ahould i also reconfigure my RPM maps to go to 8000rpm. Sorry for the n00b questions but im just trying to understand the program.
Old Feb 7, 2007 | 10:25 PM
C6C6CH3vo's Avatar
Sure
What engine modifications?
Old Feb 7, 2007 | 10:28 PM
llabmik2's Avatar
well right now im running Uicp and Licp, MBC set at 21psi, Intake, Full TBE with a cutout. 3inch 02 housing
JohnBradley's Avatar
Uberdata, a honda guy. Okay so its like this more or less, imagine the "load" as a VE table that doesnt directly correlate to a VE value (like some standalones, Crome, etc.) Load is a function of: MAF hz / Rpm *852. So as a measurement of airflow, load is a marker to establish your tuning cells. It would have been easier if it had been a straight VE table (100%=0" vac, 200%=1bar, etc.) but in a MAF system rather than a MAP I spose it makes sense.
Old Feb 7, 2007 | 10:35 PM
llabmik2's Avatar
Yea i came from NA hondas, Ok im getting it now, but why am i running higher load the what the ECU is set for, i would think that with out fuel maps and ignition maps for that load it would shut down. but eaither way it sounds like i need to set my load cells higher.
Old Feb 7, 2007 | 10:55 PM
RazorLab's Avatar
Some open air filters can throw the MAF HZ off, and then your load calc will also be higher than you think it should be. If you are not getting knock, go by the ignition timing number on the log and then locate it in the map.
Old Feb 7, 2007 | 11:05 PM
llabmik2's Avatar
Thanks that very helpful, m getting like one knock point ever once awhile.
ptm5070
Dec 18, 2014 09:06 AM
stunt2
May 25, 2012 01:46 PM
iowa_guy
Sep 21, 2011 02:32 PM
ValdezeEvo
Apr 13, 2010 11:04 PM
Boltz.
Feb 27, 2007 07:42 PM
