2byte Load hitting 336?
Old Apr 7, 2010 | 03:06 PM
ValdezeEvo's Avatar
So I installed my uego this last week. Finally got some time to log and by 3562rpm my 2byte load peaked at 336. From what I've read and researched this is abnormal on a car with my mods. My maps are maxed at 260 load and from 3343-6125 I am past 260.
Mods:
Fuel Pump
head studs
ported exhaust mani
Cone filter
3" tbe w/ test pipe
LICP
MBC ~ 24psi
ebay IC
Metal DV
A very mild setup so I dont understand why I'm hitting a 336 load and am off the map so much. Any input is appreciated.
Aaron
Old Apr 7, 2010 | 03:13 PM
RoadSpike's Avatar
Since its an 8 possibly a boost leak?
Old Apr 7, 2010 | 03:17 PM
ValdezeEvo's Avatar
I have a boost leak tester so I could go check it out. Thanks.
Currently searching the wonderful world of evom so dont bash me with the usual "do your research" reply.
Old Apr 7, 2010 | 03:33 PM
ValdezeEvo's Avatar
so could be: Boost leak, maf scaling.....
Old Apr 7, 2010 | 04:04 PM
XSivPSI's Avatar
Mine only spikes to 290 maybe 300 at 28-30 psi.
Check those things you said ^ :-p
Old Apr 7, 2010 | 04:57 PM
ValdezeEvo's Avatar
any suggestions on maf scaling? I've done some research but still a little lost on it...
Old Apr 7, 2010 | 06:11 PM
l2r99gst's Avatar
Well, you are in Denver, so you are at a much higher altitude than most others. Try logging baro+temp compensated 2 byte load and see how much it differs from uncomensated 2 byte load.
Old Apr 8, 2010 | 10:48 PM
Vigman's Avatar
Hey man! I am very interested in this since i live @7000feet and also get pretty high load levels....
Could you please explain how the 2byte load formula should looks like in evoscan to get it compensated???
Thank you very very much!
Cheers,
C>
Old Apr 8, 2010 | 11:01 PM
project_skyline's Avatar
I totally forgot about that!!!
Good thinking.
Old Apr 12, 2010 | 07:09 PM
ValdezeEvo's Avatar
I traced what the actual values for afr/timing vs rpm and then traced rpm vs load% and the values don't match up what so ever. Idk if this makes sense but it has my puzzled...
Old Apr 12, 2010 | 09:00 PM
ValdezeEvo's Avatar
I've tried searching how to log compensated 2byte load but haven't came up with anything for my rom (96420008). Any help??
This??
The 2byte load uncompensated values are the same.
Old Apr 13, 2010 | 04:00 AM
tscompusa2's Avatar
9642008 rom is garbage switch to 94170015 asap! much better support for it.
Old Apr 13, 2010 | 09:56 AM
ValdezeEvo's Avatar
I logged using IAT+Baro and it is EXTREMELY more accurate than raw load.
Old Apr 13, 2010 | 11:04 PM
EvolutinIX's Avatar
Do this, I'm at about 5800 ft. logging baro+temp at 21 psi on 91 octane and I peak at just under 240 load.
Kaveeth
Jan 26, 2015 05:35 PM
Anubis18
Jun 23, 2013 11:43 AM
kartectuning
Jun 14, 2012 08:01 PM
iXac
Feb 10, 2012 07:05 AM
mexevo
Nov 21, 2007 02:08 PM
