Getting my Evo 9 ROM
Old Feb 15, 2007 | 07:29 PM
electricevo's Avatar
Hey everyone,
I was just wondering how you DL your cars ROM and immobilizer code...Is it just a matter of hooking up the cable to your laptop with the key off, Turning the key to the ON position without starting it, and clicking "read from ECU"?
I have not come across a clear cut answer and i want to get this underway.
Once I have it, do i just append a .hex to the file and then ill be able to open it whenever or do i have to do more?
Thanks in advance and i apoligize if its been covered before,
JoshR
Old Feb 15, 2007 | 07:37 PM
EVOixMR, MalibuJack, you guys around?
Old Feb 15, 2007 | 08:08 PM
CBRD's Avatar
hook up ur cable to the obd2 port and the other connector adjacent to it..
make sure ur usb cable is plugged in before u open ecuflash.
click to read from ecu (either from the drop down menu or the icon) and then click file save as...
i usually save as "stockmap.hex"
make sure u type the .hex extension
cheers
cb
Old Feb 15, 2007 | 08:26 PM
Ralph's Avatar
^ what he said is correct.
Old Feb 16, 2007 | 04:17 AM
Thank you! I just wanted to be sure. This will also tell me my immobilizer code, correct?
JoshR
Old Feb 17, 2007 | 02:55 PM
FastAzzEvo's Avatar
JoshR
YES, Ur immob code is there after you download your map.
open up your misc section and put your user level to developer.
Old Feb 17, 2007 | 04:11 PM
kreionic's Avatar
You might need to change the setting to user level
Old Feb 18, 2007 | 09:14 AM
Thanks guys, i just found that option and changed it.
JoshR
Old Feb 18, 2007 | 11:02 AM
MalibuJack's Avatar
Great work guys.. Got his answer before I got here..
BTW This thread is a few days old, I don't know how I missed it..
mrfred
Feb 26, 2022 06:16 PM
yoyojimmy
Jan 3, 2014 12:06 PM
Blue_05EVO
Feb 24, 2012 07:57 PM
SPD_FRK
Oct 13, 2011 03:28 PM
jimn
May 15, 2008 03:37 PM
