EVOSCAN and LC-1(LC1) question
I have an LC-1 and it works just fine with logworks but I need it to work with EVOSCAN.
The values that EVOscan logs read like this(idle values).
4.8265
4.8314
4.8412
4.8461
4.8559
4.8706
4.8902
4.9
4.8951
4.8804
Any idea's?
Yes it is set up to LC-1 and the correct com port.
Yes I searched.
Thanks in advance.
4.8265
4.8314
4.8412
4.8461
4.8559
4.8706
4.8902
4.9
4.8951
4.8804
Any idea's?
Yes I searched.
Thanks in advance.
If not, do another heater calibration but instead of 20 seconds try 60 seconds (cold outside) then do another free air.
Problem is the readings should go no lower than 7.8 with LC1
Just select LC1 WB and use the default COM for evoscan
I got it to work. In LM Programmer software I had to set the drop down box(there is only one) to the proper value.
Now evoscan works just fine. You need to restart the car in order for changes to take effect.
This is for an innovate LC-1(lc1) wideband.
i havent decided yet, i just bought a laptop and i'm still looking at all my options. i just like the minimalism of the lc1... i might do a gauge eventually.
Honestly I wanted to DIY a wbo2 controller but the calibration, plus heating circuitry make it a little more than i'm willing to spend time on. The pricepoint on the LC1 makes DIY not even worth it.
mj, would you hurry it up with that already?
The LC-1 is relatively cheap.
3vo|3oost
May 7, 2017 01:10 AM
Rokpapaziz
11
Jun 6, 2013 12:30 AM
