EvoScan v0.98 Now with Power & Torque Graphing - Map Tracing completed also!
Old Feb 27, 2007 | 11:05 PM
  #121
codgi's Avatar
^^ poor MJ getting signed up for more work
Old Feb 27, 2007 | 11:16 PM
  #122
jfitzpat's Avatar
Originally Posted by Evo_Kid
First I know nothing of this situation, but in the first link it just seems like he wanted some help. When it was recieved, it seems he said thanks and such. Whats wrong with that???
Nothing, as noted, we take our obligations to customers seriously and actively support 3rd party development.
The second thing about him saying theres no serial port, seems like a mistake.
Could be, but I doubt it. You write code to support the LC-1 serial output. You come to us for help. You announce the support a day later. You boast about the support in a thread a week after that. And answer questions about the support a week later still. But four weeks later you state that you have personally investigated and the port does not exist?
Then the statement about "analog " and you guys not being "fast", isnt that true??? Doesn't you system only pick up 12 samples per second???? If that is correct, then it is slow. If not, coorect me.
Fundementally wrong in two regards. First, he postulated that no serial port existed, so the subject would be our analog outputs. They are not just 'among the fastest', they are the fastest, by a wide margin. You can actually see individual valve activity on a scope and we provide a mechanism to slow them down to mimic conventional, current based, wideband controllers.
Second, comparing serial sample rates is totally a red hearing. A LC-1 typically takes discrete measurements about 400-500 times per second. Every measurement is converted into lambda, and there is no PID control loop involved. We use a patented measurement principle. When you are monitoring the serial output at 12 Hz, every *lambda* measurement in that interval is averaged and the result is output.
So, if lambda changes, the response time of the instrument is a worst case of about 83 mS serially. And, because it is an average of lambda measurements, abnormal combustion events show up as expected. You can demonstrate both these for yourself. A single miss (air, no hydrocarbons, infinite lambda) will show up as a one sample spike when logging serially. Similiarly, if you cut your ignition switch WOT, the log will shoot to O2 in a couple of samples, which is exactly what the engine is really doing.
On the other hand, a conventional, current based wideband does not take lambda measurements 400-500 times a second. It typically takes 1/lambda measurements about 4-10 times a second and feeds them into a PID style control loop. Because of the way the sensor works, the feedback in the system is not used for measurements (it is actually always dithering around the same point, equivilency), the output of the *control loop* is used as a measurement. This means that when lambda changes, the new value is not reflected at the sample rate (normally referred to as tao), but typically at 5 tao (.5 seconds on a good controller, .9 to 1.2 seconds on a poor one).
In other words, the speed that readings are reported serially is irrelevant, the limiting factor in the response time of the instrument is the measurement principle and the implementation of the PID style control loop. Again, you can prove this for yourself. The single puff of unburnt mix (infinite lambda) that showed up as a spike on the LC-1 shows up quite differently on other controllers. It is treated as 1/lambda (effectively 0) and fed into the control loop. Instead of a spike, you get a long hump of artifically lean readings. If you are getting occassional misses (idling too rich, or too cool for the points), you don't even get a hump. You just get steady readings that are 1.0 to 2.5 AFR too lean.
Similiarly, try killing the ignition switch at WOT and watch the output of a current based wideband. The engine filled up with O2 in a couple cycles, but the wideband will, as designed, take .5 to 1.2 seconds to catch up to that state. In both these cases it does not matter if you report the .5 to 1.2 seconds (or the hump) 10 times a second, 50 times a second, or a 100 times a second over a serial port, the values are still wrong. So the response time of an LC-1 reporting at 12 Hz is still, worst case, 6 to 14 times faster.
If you need faster measurements still, say for a specialized application like race engine valve tuning, you can switch to the LC-1's analog outputs.
Reguardless if he is, hes making a product, and trying to make money. Whats wrong with that?? Dont you guys do the same thing???
Actually, that was my point. He wouldn't tolerate certain treatment from us, or certain activities by his customers. And, as I said, I believe in the Golden Rule. That's just my opinion, not Innovate's (Felipe and I would have gotten canned for not legging out his 'it doesn't work and your support staff does not answer my posts', regardless of my thoughts on its legitimacy).
-jjf
Old Feb 28, 2007 | 12:04 AM
  #123
Inprogress's Avatar
You sure offer a solid package deal for the 1.3M USB cable and the software, can't wait to place my order.
Thanks!
Old Feb 28, 2007 | 01:58 AM
  #124
evo4mad's Avatar
jfitz, you're cool, chill out. the innovate products are awesome and fast, I agree, thats why I bought one. Do you get paid by innovate per line for forum posts or something? lol.
Old Feb 28, 2007 | 01:59 AM
  #125
hawaiian_evo's Avatar
innovative got really great customer service too
Old Feb 28, 2007 | 02:10 AM
  #126
MartynJeffery's Avatar
Will existing customers be e-mailed the new version or will there be a seperate download site for them......
Old Feb 28, 2007 | 02:47 AM
  #127
JoeBee's Avatar
Come one. Even if you stand with the back to the wall it is not a good style to bite around.
Old Feb 28, 2007 | 03:20 AM
  #128
cij911's Avatar
I will release it in 10hrs from now.
I am here waiting lol....6:19 am 2/28....I can't wait ...
Old Feb 28, 2007 | 04:02 AM
  #129
evo4mad's Avatar
Jfitz knows i'm just joking around, he won't take me seriously.. aye jfitz.
Old Feb 28, 2007 | 05:02 AM
  #130
XK120's Avatar
No email yet...anybody else get it???
Old Feb 28, 2007 | 05:08 AM
  #131
C6C6CH3vo's Avatar
Wake up Evo4mad,
It's time to send us
EVOSCAN v0.99
Old Feb 28, 2007 | 05:09 AM
  #132
Evol.ved's Avatar
No. I had been hoping to download/install beore work.
Oh well. Maybe tommorrow
Old Feb 28, 2007 | 05:12 AM
  #133
bvdawg13's Avatar
wow, i had a dream about this last night lol....
but its still not out yet.
Old Feb 28, 2007 | 07:02 AM
  #134
Chino1's Avatar
i cant wait to have the update...
Old Feb 28, 2007 | 07:05 AM
  #135
Peteypab2133's Avatar
im excited and i dont even know how to use it... looks like i will have to start playing with the lap top in the car
