EvoScan v0.98 Now with Power & Torque Graphing - Map Tracing completed also!
Old Mar 29, 2007 | 12:23 PM
  #466
slavsevo8's Avatar
patience is a virtue...
Old Mar 29, 2007 | 01:19 PM
  #467
RedV's Avatar
JUST KIDDING!
Old Mar 29, 2007 | 01:25 PM
  #468
slavsevo8's Avatar
hahaha...love it
Old Mar 29, 2007 | 07:54 PM
  #469
roberttonge's Avatar
thanks
Originally Posted by Jazzie604
let me try to get these right...
AccelEnrich- used only as a momentary adder for fueling as you are moving the gas pedal, to prevent a lean tip in moment, like an acclerator pump on a carb
FuelTrim_Low/mid/high-only used in closed loop operation(around town driving) and the computer ignores these while at WOT
CoolantTemp-once warm, a properly function cooling system is supposed to keep this a very stable number. If the temperatures climbs more than a few degrees on a dyno/street pull, youve got issues that need addressing
O2FeedbackTrim-again, during closed loop only, this is what the comp uses to reference fuel trims off of
O2Sensor- should be the precat sensor, if fueling is correct this wont change a lot either, indicating steady fuel trims, just not giving accurate reading for tuning off of
O2Sensor2-I think this is the post cat o2, which is used just for emmisions purpose
I think I got all of this right, but someone let me know if I screwed up.
Thanks for the info, PS i just got evoscan .99 its amazing lol
Old Mar 29, 2007 | 07:58 PM
  #470
EvoDan2004's Avatar
how is .98 coming alone. are the bugs fix'd?
i got .99 but for some reason it wont start logging. .97 logs fine but .99 wont log. it says it starts then says it stops. help?
Old Mar 29, 2007 | 08:16 PM
  #471
RedV's Avatar
I ran into this problem as well. Try making sure your cable drivers are installed and working correctly. I ended up removing the device and letting it reinstall, after that I was able to log successfully with .99.
Old Mar 29, 2007 | 10:44 PM
  #472
Evo_Jay's Avatar
My .99 works fine. The power graph works too.
Old Mar 29, 2007 | 10:58 PM
  #473
PDXEvo's Avatar
wait a sec here, so did v.98 ever get officially released? I gotta admit, I got tired of reading all of the BS in this thread around page 15. I swear, if you took out all the crap, kinda like my post apparently, you would only have 2 or 3 pages of stuff to read. So, back to my original question, did .98 ever get properly released with the bug fixes? Or are we jumping to .99 on the down low?
Old Mar 29, 2007 | 11:32 PM
  #474
tephra's Avatar
.98 was never official released
.99 will be out soon - its going through beta testing at the moment.
Old Mar 30, 2007 | 03:03 AM
  #475
cij911's Avatar
So are there issues with LoadCalc in v.99 ? Also, I v.98 I cannot seem to find where evoscan is capturing my boost from my Zeitronix WB. It is not the MAP column as this just goes right to 329.5 by 2500 at WOT...Any advice? Thanks
Old Mar 30, 2007 | 04:09 AM
  #476
bigric09's Avatar
if its like evoscan, you have to check the box for wideband O2
Old Mar 30, 2007 | 07:39 AM
  #477
EvoDan2004's Avatar
i would asume they are because it works for .97. how do i check i dont know
Old Mar 30, 2007 | 09:03 AM
  #478
evo4mad's Avatar
====admins Please Lock This Thread... No More Posts Please===========
Johnny Boy
Feb 16, 2010 12:51 PM
evo4mad
Mar 22, 2009 08:38 PM
mscorei
Aug 1, 2007 04:10 PM
evo4mad
Jul 8, 2007 07:27 AM
evo4mad
Oct 12, 2006 11:30 PM
