has anyone been able to get their AFR curve this flat with ecuflash? :P
Old Mar 1, 2007 | 09:27 PM
krillin's Avatar
i think this was done with safc though. i honestly don't see how the plot can be so smooth.
are there any zeitronix owners that can post their plots? i'm just curious as to what other people can achieve that i can't... :P my curve has dips and humps that are hard for me to tune out especially since the value is in between adjustable rpm's (ex. wanna flatten 4300rpm but only have 4000 and 4500 to adjust and the AFR is, let's say 11 at 4000 and 4500 while 4300 its at 11.3)
Old Mar 2, 2007 | 12:39 AM
Dapper Dan's Avatar
you could always rescale your maps to fine tune certain areas.......it can be done.....
Old Mar 2, 2007 | 05:12 AM
C6C6CH3vo's Avatar
Hell yeah, even with methanol ramping up to 625ml/min. All except for one little dip at peak, but thats at 24psi
Problem is if the weather changes 2 degrees or barometer changes one bit, my A:F will change too.
See how it looks when you start a pull at a higher or lower RPM
Old Mar 2, 2007 | 05:17 AM
Evo442's Avatar
fwiw, I have found my afr's to be a fair bit more stable once I installed a mbc and quit trying to control boost with the ecu. seems like the stock bcs with stock solenoid takes a lot of fine tuning to get really smooth. I'm too lazy.
Also, it is possible to rescale the maps to add some resolution at a particular rpm etc. I think it was Malibujack who wrote a very nice tutorial on rescaling the load colums. Its conceptually the same as what you want to do with rpm.
Old Mar 2, 2007 | 05:29 AM
C6C6CH3vo's Avatar
Kind of OT but let me piggy back off that:
I basically pulled up to 6 degrees timing, most at peak, but added 1 deg at redline. Of course the A:F respectively got richer, but after pulling the respective fuel I was dumping in for the unnessesary amount of timing, my A:F became linear, stable, less dipping, and even less spikes from added heat - the fuel I was using to allow timing and reduce temperature actually was the cause for it being needed.
Hiboost
Outlander Sport
60
Jul 17, 2014 01:33 PM
smanders
20
Feb 14, 2013 01:08 PM
razorlab
40
Mar 10, 2008 11:19 PM
SophieSleeps
Jul 19, 2007 04:54 PM
EVO8LTW
Jul 1, 2005 09:56 AM
