Evoscan log with AFR(uego)
Old Mar 23, 2007 | 05:19 AM
zbomb's Avatar
Originally Posted by C6C6CH3vo
Are you spraying late?
Your making massive power, but that lean spool needs to be fixed right away! Once in the 11's it bounces up and down abit, but you can fix that later. I would pull 2 - 4 degrees from 3750 to 4500 rpm too but it will take some work to regain the power but it will be consistant, believe me I had 9's there too.
First and foremost, either spray the methanol earlier or add about 2points fuel down to like 90% load, You put an intake on there or something
I have and was tuned for a ARC intake.
Old Mar 23, 2007 | 09:05 AM
Mellon Racing's Avatar
Originally Posted by coolguycooz
but, i would go with what C6C6CH3vo said, why not pull 2 degrees right there, and add a tad bit of fuel? see what happens, if your runs stay consistent, heck why not go back in and add a degree back, if your AFR stays solid,
the only reason you would pull timing out is to lessen knock and he doesn't have any so that doesn't make any sense.
just add fuel to get the AFR in the 12's during spoolup and out of the 13's If it still isn't knocking you might be able to add timing to increase the torque off boost.
Old Mar 23, 2007 | 03:25 PM
zbomb's Avatar
what is everyone running for afr in the 3-4k rpm if you don't mind sharing. What is the concensus for a safe afr during spool up.
Old Mar 23, 2007 | 05:41 PM
C6C6CH3vo's Avatar
Title of his log is "good pull".
One account of no knock is not a good way to determine if timing is too advanced and several degrees beyond available power gains, unless your limited on time, resources, and knowledge.
Believe me, 4 degrees at peak can feel just as good as 10* at peak without knock. It just takes more work to get there - Bubba
Old Mar 23, 2007 | 06:03 PM
zbomb's Avatar
hahah, funny you noticed the "good pull" title. I have had a recent problem of blowing the intercooler pipe off the i.m. while logging. The "good" does not reference the tune, it references the log, it's good "data".
Old Mar 24, 2007 | 03:38 PM
zbomb's Avatar
added another log to 1st post.
superkizuna
Apr 28, 2014 09:43 PM
07EvoIX
Oct 28, 2012 12:49 PM
Tbtalon94
Nov 2, 2010 11:49 AM
Walt
Jul 21, 2009 05:45 AM
eponti
Sep 29, 2007 11:41 AM
