A tuner question!!
Old Jul 20, 2009 | 02:24 PM
Walt's Avatar
A tuner question!!
I dont understand how my tuner logged boost while tuning if i didnt have a 3 bar map and he didnt put a map sensor in. I started doing some datalogging with evoscan and want to log boost, afr's etc.. Just curius because I'm just starting to learn more about my car as i start moding it. Thanks guys!
3" tbe
hallman mbc
samco intake w/ 4.5 k/n
ets 3.5 intercooler kit
boost gauge, oil pressure, aem uego
Old Jul 20, 2009 | 03:20 PM
godnf8's Avatar
I'd assume he guestimated using your boost gauge unless your boost gauge has an output for logging
Old Jul 20, 2009 | 04:09 PM
EVOIXreno's Avatar
Did he tell you to set it to a certain boost?
Old Jul 20, 2009 | 04:48 PM
JohnBradley's Avatar
If you dont have one of the intake pipes that completely alters the MAF (i.e. ARC, HKS, etc.) you can actually estimate boost off load if you know what to look for. Somethings like cams and exhaust will alter it but as relatively stock as your car is it wouldnt be too hard to estimate.
Option 2 is as has been stated he just did a good job of watching the gauge if he was in the car.
Who is the tuner?
Old Jul 21, 2009 | 05:19 AM
Walt's Avatar
Who is the tuner?
Chris at efi logics in Ct
Old Jul 21, 2009 | 05:24 AM
Walt's Avatar
I have a auto meter boost gauge which i think is off a little because it bounces around from 22psi to 24 psi at peak boost. On my dyno sheat it says i hit 22.3 psi max.
Old Jul 21, 2009 | 05:28 AM
recompile's Avatar
If you were dyno tuned, then he probably teed in a vac line, as all dynos are meant to log boost directly from a boost source on the car.
Old Jul 21, 2009 | 05:45 AM
Mellon Racing's Avatar
a good tuner can detect subtle changes in air pressure by feel... I'm kidding
Anubis18
Sep 20, 2013 02:39 PM
BigSteve
Sep 4, 2010 12:28 PM
cableguy5752
Mar 15, 2009 04:19 PM
savior1974
Nov 7, 2007 05:26 AM
kouzman
May 18, 2007 03:42 PM
