tuned our 2.3 evo project car with ecuflash...
Old Apr 1, 2007 | 09:06 AM
CBRD's Avatar
hey guys,
we did some tuning yesterday on our JAM 2.3 with stage IV head....
gt35R .63 hotside... 850 injectors...
car started off around 260whp at 12psi... (stock evo's make about 220ish on our dyno)
With 25 psi on pump gas we were able to make 441whp/358 wtq...
backing it down to about 23.5 psi, and running more conservative I was able to make consistent 385-390whp and 330ish wtq.... but... the wtq is over 305 from 4300 to 7000 rpm, which is amazing....
ill post some charts this coming week, its been a long hectic past week.
cheers
cb
Old Apr 1, 2007 | 09:13 AM
evodrivesme's Avatar
how are u not making up in the 500+ range with that setup!!
Old Apr 1, 2007 | 09:14 AM
i know im runnin meth but as is in my car im doin 450/450
Old Apr 1, 2007 | 09:17 AM
CBRD's Avatar
our dyno reads quite low.... comparable to buschurs...
the car lights up the tires in first and is sideways through second, with 265's the whole way around
on race fuel I think we will see 500whp easily on our dyno, which is about 600 on a dynojet (nothing to sneeze at on a stock ecu'd car)
cb
Old Apr 1, 2007 | 09:18 AM
CBRD's Avatar
by the way... 365 whp on our dyno is about 410 on a dynojet... so you need to take that into consideration
Old Apr 1, 2007 | 09:20 AM
scorke's Avatar
Sweet Chad, I hope my setup compared, which cams?
Scorke
Old Apr 1, 2007 | 09:23 AM
CBRD's Avatar
stock cams,
i have some custom GSC's coming, greg thinks they are worth another 30wtq or so...
should be a monster....
- your car is pretty awesome too, 2.3's rock for the street... mine purrs so nice, JAM balances and tolerances the balance shafts... its smoother than stock... we can rev to 8200, but im keeping her to 7400
cb
Old Apr 1, 2007 | 09:29 AM
Rexpeed's Avatar
very nice I got the same stroker kit Are you running the Venolia kit?
Old Apr 1, 2007 | 09:35 AM
CBRD's Avatar
yessir, their stuff rocks,
JAM is 45 mins from me hee he.. we have a few customers coming in to have heads and blocks built by them!!
they are top notch!!
we purchased the two highest stages of their block and head... and the engine looked so nice, i didnt want to assemble it!
cb
Old Apr 1, 2007 | 09:42 AM
Rexpeed's Avatar
45min away lucky you
Old Apr 1, 2007 | 09:44 AM
CBRD's Avatar
also,
this is an evo 8 not ix, for those that care lol
cb
Old Apr 1, 2007 | 11:34 AM
CBRD's Avatar
the AFR is off because of a leak in the nice RNR o2 housing lol before both of my widebands... this was 25psi through the entire pull, to 7500 rpm, i backed it down to 24 psi and lowered the power to 385whp for now.
im probably going to throw the wideband in the primary o2 spot to check it...
Old Apr 1, 2007 | 11:47 AM
Cali2MDevo8's Avatar
Registered User
Great work! Look forward to seeing this beast when you install my GSC S1's in the next week or so!
Not sure if i want to get on your dyno. I'll be dissapointed when my 8 only makes 270whp with cams. LOL
Old Apr 1, 2007 | 02:25 PM
DS-03evo's Avatar
Wow.. that is great. All of this is done on stright 93, no meth right?
Old Apr 1, 2007 | 02:27 PM
CBRD's Avatar
no meth,
im waiting for the stage 3 snow kit...
on race fuel im going to attempt to run 38psi, i think we will hit mid 500's pretty easy
cb
