OEM Style Gauges for EvoScan .99
Ok I am back I had to reformat my laptop and I just spent the last 2 days geting it up to speed. I will be working on the merged gauges tonight
edit : I have v2 merged and some modded sets including a white face "ralliart" set and I will also be creating a blueish white # set to match the nice overlay I have in my car I havent decided if I am going to make a new thread but either way I will be posting what I have done so far sat evening in this thread
It took a while to figure out 1 or 2 things but here ya go
these are variations of the oem v2 set all have a very large squarish led at the top that only shows at knock levels of 7 and higher all other changes are purely cosmetic. I have included layout files that have most settings assigned and a moderate size that should be ok on most newer laptops, if its too big or small you can create your own using the edit gauge widgets function
oem v2 combined and altered slightly
download
Blue eBay overlay (the nice one)
download
White Ralliart style
download
I am going to create from the ground up my own set to release, when completed I will post. It may take a couple o weeks
download
download
download
i tried loading the stock gauges posted by andenbre and playing back a few saved logs.... the gauges arent responding. I opened the other few gauge setups i have and they all work just fine. Are these just appearance only for now ? or should they be working
Are you able to log/create the IDC % on the fly with EvoScan .99? I copied the same formula into both .99 and the 1.2 beta and I get all 0's in .99 and correct values in the 1.2 beta.
I take it you added the formula in evoscan for the IDC right? If you did make sure that RPM and IPW are above the IDC in the XML. Evoscan logs from top to bottom so any thing that gets calculated in evoscan needs to be above the new formula. Kind of like a+b=C (which is a calculation on A and B_ So in the XML it needs to be logging order of
A
B
C
A
B
C
A
B
C
Hamish already had it below both in the data item editor in 1.2 beta.
Thanks.
cool, maybe my playback is being retarded with those gauges. Once i do a fluid change today i am going to do some logging. I will check it out then. maybe i have the same problem Charlie was discussing with the columns being out of order since mine are all rearranged.
