OEM Style Gauges for EvoScan .99
OEM Styled Gauges for EvoScan .99 (v.002)
Download Left Side http://www.frameleft.com/evo/evoScan...ges002Left.jpg This file includes: Speedometer (MPH + KM/h) 3-stage Speed Warning Indicator (80, 100, 110) Tachometer 2-stage STi-styled Shift Light (6k, 7k) AFR Display AFR Indicator Lights for Open Loop Operation Closed Loop Indicator Download Right Side http://www.frameleft.com/evo/evoScan...es002Right.jpg This file includes: Coolant Temp TPS Full Throttle Indicator (95% - 100%) Boost (for JDM MAP) Knock Count 3-stage Knock Indicator Load Timing Advance Octane Intake Air Temp Injector Duty Cycle Mapping Info: Speedometer - Speed Speed Warning Indicator - Speed Tachometer - Engine RPM Shift Light - Engine RPM AFR Display - Wideband AFR (Wideband O2 sensor required) AFR Indicator Lights - Wideband AFR (Wideband O2 sensor required) Closed Loop Indicator - O2 Feedback Trim Coolant Temp - Coolant Temp TPS - Throttle Position Full Throttle Indicator - Throttle Position Boost - JDM MAP (Instructions Here) Knock Count - Knock Sum Knock Indicator - Knock Sum Load - Calculated Load OR 2-Byte Load Timing Advance - Timing Advance Octane - Octane Level Intake Air Temp - Air Temperature Injector Duty Cycle - Must add IDC% formula to data.xml file (Formula found here) Here is a layout file with values already assigned. Instructions: 1. Download the left and right side XML files above using the right-click > Save As... method. 2. Save the files in your "EvoScan v0.99/GaugeTemplates" directory. 3. If you want to use the provided layout file, download the layout XML file to the "EvoScan v0.99/GaugeLayouts" directory. 3 a. To load the provided gauge layout, select "Gauges > Load / Display Gauge Layout" from the EvoScan menu and select the layout you've downloaded (i.e. oemGauges_002). 4. Open EvoScan. 5. From the top menu, select "Gauges > Add/Edit Gauge Widgets." 6. From the pulldown menu in the new window, select one of the new gauge files you've downloaded (i.e. OEMitsuGaugesLeft) 7. Assign the input values as noted above by right-clicking the image of the gauges. 8. If you would like to re-size the gauges, click and drag the lower-right corner of the window until they are the desired size. 9. When you are done, click the "Create New Widget" button at the bottom of the window. 10. You can move the gauges around by clicking and dragging the gauge window. you can also change assigned input values or close the gauge widget from the right-click menu. 11. To save the layout you've set up, including all of the mapped input values, select "Gauges > Save Current Gauge Layout" from the EvoScan menu. Enjoy. ---------- Andenbre's Combined Versions: OEM Style https://www.evolutionm.net/forums/at...1&d=1190089217 eBay Blue https://www.evolutionm.net/forums/at...1&d=1190089257 RalliArt White https://www.evolutionm.net/forums/at...1&d=1190089257 |
Good Job. {thumbup}
People are gonna love these |
YAY!! I'm one of the (probably thousands of) people who PMd you about these earlier. THANKS!! {thumbup}
Very nice work.
I'll have to look at the xml cause it looks like you were able to get the gauges close without having the background overlap/intersect the others. |
Originally Posted by laakness
(Post 4162336)
I put the layout in the gauge layout folder and the left and right side into the gauge templates.. But it comes up as an error.. I tried swapping them into the opposite folders and got errors as well.. which goes where?
Is this cuz I still using 0.97? |
It could be because of .97, I'm not sure. The left and right files go in the templates folder and the oemGauges.xml goes in the layouts folder. You have it right.
Ya I thought so.. I have other gauge layouts and they work fine... hmmmm anyone still using 0.97 and this works?
Gauges work... but I can't resize them? anyway I can tweak it to make it smaller
You will not be able to resize them from the layout file provided. You have to resize them from the "Add Gauges" window, so you'll have to make all of the associations again. No big deal though.
Cool.. thanks..
Thanks. I was just thinking about gauges like these, but didn't know how to make them.
Well done. Thanks!
I downloaded both templates and the layout but when I load the gauges only the left side would open.
Yes I do have v.99 |
great work man {thumbup} :mitsu: :beer:
