ECUFlash / Evoscan / Mitsulogger Questions
Old May 16, 2007 | 08:18 PM
  #256
TouringBubble's Avatar
I got the IDC% calculation to work using the RequestID that the 2-byte RPM mod references. I'm not sure if it really matters, but I got it to work either way.
Code:
<DataListItem DataLog="Y" Color="" Display="Injector Duty Cycle" LogReference="IDC%" RequestID="02" Eval="([InjPulseWidth]*[RPM])/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" Notes="([InjPulseWidth]*[RPM])/1200"/>
Old May 20, 2007 | 08:22 AM
  #257
Q8_EVO's Avatar
got a new laptop that has Vista on it
I installed ECUFLASH.. But Vista wont recognize the driver for the TTrix Cable
Old May 27, 2007 | 04:32 PM
  #258
Jer.k's Avatar
missing info in "connect to ecu"?
(problem fixed,pathway changed on its own I just changed it back to the way it was)....I installed a jdm map sensor and 720 fuel injectors along w/ the corrections to the
rom and injector size and latencies.Uploaded it to the ecu and now when I try to
connect to the car's ecu the small screen pops up to choose the car your trying to
read from and nothing is in the box.Anyone have any idea what happened and
how to fix?....thanks
Old May 28, 2007 | 05:17 PM
  #259
awdcomplex's Avatar
Originally Posted by vmrevo9
Hey guys i'm trying to figure out how close to accurate is the road dyno graph? To what dyno does it compare to. And what are the differences between the ratios of an evo 8 5spd to an evo 9 5spd. The main reason I am asking is because we did a dyno log and we didnt change that setting. I had made 318hp and 312tq torque but that was under the specs of an evo 8. I have the 9. i also had 4 people in the car to include myself which totaled 630lbs and a half a tank of gas.
Any info is appreciated.
https://www.evolutionm.net/forums/sh...&postcount=179
just thought i share my experience with the evoscan dyno feature
Old May 29, 2007 | 07:13 AM
  #260
vmrevo9's Avatar
Veteran: Air Force
thanks for the info.
Old May 30, 2007 | 03:18 AM
  #261
Bonestock!'s Avatar
I tried causing a CEL by unhooking the MAF sensor and starting the car. When I connected EVOSCAN to it, it couldnt find or clear the DTC???????
Old May 30, 2007 | 08:38 AM
  #262
TTP Engineering's Avatar
Evoscan does not find or clear trouble codes.
Old May 30, 2007 | 10:00 AM
  #263
Bonestock!'s Avatar
Why would it have that option there on the lower left?
Old May 30, 2007 | 10:14 AM
  #264
To confuse you.
Old May 30, 2007 | 01:48 PM
  #265
Bonestock!'s Avatar
All part of the evil plan huh?
Old Jun 3, 2007 | 06:42 PM
  #266
SICK9's Avatar
Code:
So i tried copy and pasting this into my evoscan/data settings and I keep getting an error saying:
"CANNOT CREATE DATA.XML FILE ETC. ETC.
MAKE SURE PATH AND FILE NAME ARE CORRECT"
I opened it up using notepad and wordpad also, same thing happens each time.
I'm using vista..
tia, jamie
Old Jun 3, 2007 | 10:36 PM
  #267
lemmonhead's Avatar
what baud rate is it suppose to be set at, for some reason mine got errased and now I cant use evoscan
Old Jun 4, 2007 | 10:41 AM
  #268
lemmonhead's Avatar
nevermind I found it, something like 15256.
Old Jun 14, 2007 | 10:55 PM
  #269
eponti's Avatar
can you log your AFR by using mitsulogger?I noticed that there was a column that says AFRMAP but not sure coz i get numbers like 128
Old Jun 15, 2007 | 05:17 AM
  #270
I'm using vista..
tia, jamie
It sounds like you are saying that you can't add this to the XML file. I would suggest using Notepad rather than Wordpad. On my machine (XP), the default to open XML files is Internet Explorer in which you cannot edit the XML. Personally, I use Dreamweaver to edit my XML files.
If you are still having trouble, PM me and I'll send you my e-mail address. You can send your data.xml file to me and I'll add it for you.
