Idle Stepper Look-Up Table Alittle messed up...
Old Apr 5, 2007 | 10:06 PM
C6C6CH3vo's Avatar
With ECUFLASH 1.26, 1.27, and 1.28 my ROM would be recognized as 96420008 (2004) and would have the same y axis wack as that - DONT CHANGE THE VALUES.
With ECUFLAsh 1.29 and up, my ROM was recognized as 96420007 and stepper look up was normal.
Search
Old Apr 5, 2007 | 10:10 PM
C6C6CH3vo's Avatar
Originally Posted by gsrboi80
Both my GF and I Idle Stepper Look Up tables look like yours. She has an 04 RS
Internal ID: 96420008
Her values are all wacky also
So if you find the fix let me know
Are you using 1.29a or 1.3?
If you attempt to change them to the normal looking values the ECU will see them as values as screwed up as the ECUflash is giving you, so don't change the values- it's just the software
Old Apr 6, 2007 | 07:39 AM
20psiMR's Avatar
Sounds like that 0008 definition is a little wacky. I think that definition I posted up is actually for 03's, I looked at a friends rom I have saved that I know for sure is an 03 and he used that one. So thats why it didnt work. I would upgrade to 1.29 if you havent already, and use the 0007 def. If you need it, I can post it too. I checked mine just now, c6 is right they come up with 96420007 and the stepper table looks just like yours only with correct axis.
Old Apr 6, 2007 | 11:59 AM
Spooldyou's Avatar
I'll let you know if there a fix, i have tried a few different things, and i even went as far as rewriting the code in that Rom.
Im using Version 1.3.... which is the latest version. ... i understand but its the fact that some of the vaules in the X and Y axis are exactly the same, is whats bothering me. Your correct i could just leave it alone, but that would defeat the purpose of the thread.
right, the Axis is again what im talking about, its what messing up my values, if i change the defination, and or the adress, it messes up the entire map, im kinda lost as far as that goes
Old Apr 6, 2007 | 12:05 PM
Ludikraut's Avatar
^ get rid of your existing definition in ECUflash and let it re-discover the ECU type and associated map. Might want to even uninstall ECUflash and make sure to get rid of (or at least move) all existing XML definition files before re-installing.
l8r)
Old Apr 6, 2007 | 02:17 PM
C6C6CH3vo's Avatar
I think I did something like that when I installed 1.29a and then miraculously my ROM became the same as the ID lable and the look up was fixed.
I remember befor, back when it was screwd up (with the 0008 ID), I bravely pasted the correct values over my incorrectly looking values after being fed up with the way the ROM axis was presented. I started the car up and it ran just fine for 0.8 seconds, but suddenly the car stuttered and shut off while making a bunch of wrong sounding electrical clicking noises. I felt guilty so I changed the oil with some brand new (back then) Extended milage M1 oil and replaced her filter. I think she forgives me now by the the thrills I recieve but I also keep her drunk.
Old Apr 7, 2007 | 08:21 AM
Spooldyou's Avatar
l8r)
already did that too, I think what i might do is Flash the rom with a different ID number. And try rewriting the code for a totaly different rom. Or mixing just that portion of the code.....
I know im not explain it the best but, i will post my results.
Old Apr 7, 2007 | 12:37 PM
Ludikraut's Avatar
It would probably be easier just to look at the hex code of your ROM and compare it to a known working 2004 ROM and then figure out where the axis reference for your ROM is at. That way all you have to do is fix the reference in the map.
l8r)
Old Apr 7, 2007 | 12:46 PM
Spooldyou's Avatar
l8r)
I've have already tried to rewrite the code using another rom, Using a rom from another year, some roms i got from OPENEcu.Org and some others i found on the internet. So far, nothing yet. If i change the adress, and modify the rom, The rest of my tables ( Example: HIGH Octane, fuel map) values get messed up....
Malibu where are you!!
Old Apr 7, 2007 | 12:59 PM
Ludikraut's Avatar
If you want to e-mail me your ROM file, I can take a stab at finding the right axis for you... might take me a couple of days, though. Kinda busy these days...
l8r)
Old Apr 7, 2007 | 01:11 PM
gsrboi80's Avatar
Im running 1.3. I know its in the software just wondering how to fix it
Old Apr 7, 2007 | 02:00 PM
Spooldyou's Avatar
l8r)
you got PM
tephra
70
Jul 11, 2024 12:59 AM
tephra
Jun 9, 2010 11:22 PM
evoredy
Feb 7, 2009 05:38 AM
RyeLou
Aug 27, 2008 08:16 AM
