Idle Stepper Look-Up Table Alittle messed up...
Old Apr 5, 2007 | 12:00 PM
Spooldyou's Avatar
Now i might be wrong, but i was going through my map tables, and found this table and though that it might have to do something with my idle. I was looking though other maps that i have aquired from other members, and noticed that my Idle Stepper Table looked extremely wierd
MY QUESTION
: If the fact that my car has an 04 ECU, does that mean that my table is supposed to be like that? Every map that i have looked up is from an 05 and i dont know if my maps alittle off. So please Check it out and let me know what you think.
MY MAP!
And one of the maps Im comparing them too..... Completely Stock 05 ECU....
Old Apr 5, 2007 | 01:01 PM
Spooldyou's Avatar
OK, SOO.....11 views and no one has a clue ????
Old Apr 5, 2007 | 01:20 PM
PVD04's Avatar
My idle stepper lookup table looks similar to yours, although your axis addresses appear to be messed up.
-Paul
Old Apr 5, 2007 | 01:25 PM
Ralph's Avatar
You probably have selected the wrong ECU definition file.
Old Apr 5, 2007 | 01:29 PM
Ralph's Avatar
See:
https://www.evolutionm.net/forums/sh...d.php?t=211159
This post:
https://www.evolutionm.net/forums/sh...93&postcount=6
Same problem, probably wrong definition file .
Old Apr 5, 2007 | 01:31 PM
kmcconn9's Avatar
Either this or something is up with the idle axis column as all 5 maps I have acces to do not look like that...and only one is an 05.
Old Apr 5, 2007 | 02:01 PM
Spooldyou's Avatar
if I side click and go to "edit Map" and check out the adress my origanl map, and the map that i posted, for all the ECU's that i have flashed this seems to be one of the only ones that i have run into with this map adress.... maybe im doing something wrong here.?
Old Apr 5, 2007 | 02:30 PM
20psiMR's Avatar
Your using the wrong definition....all my maps that are from 2004's are using this one:
I show same exact values for 03 and 04 ecus as you have in your table. The 05's and 06's are the same as the one you posted for the 05 rom. So shouldnt be anything wrong with yours except the definition your using that is scewing the RPM axis. Also, just to test, what you can try is use the addresses from the 94170008 that I posted. Here they are:
Attached Thumbnails Idle Stepper Look-Up Table Alittle messed up...-untitled2.jpg
Old Apr 5, 2007 | 02:39 PM
20psiMR's Avatar
ooh...just noticed the addresses are both the same. Weird, my definitions x axis comes up just fine. Here is the def if you want to try it out, just cut yours out of the rommetadata folder so that it asks you for a new def when you open your map again.
Also, change it from a .txt file to .xml or it wont work
File Type: txt
Old Apr 5, 2007 | 03:31 PM
Spooldyou's Avatar
well tried that and now all the other maps are completly off. and tooo boot, my idle stepper map still isnt reading right.
So to answer your question, no... that didnt work. Next idea please.
Oh and let me remind you that IM running 1000cc injectors, 280 cams, ECT. BUT! that should have ZERO affect on the stock why that table is reading like that .
Old Apr 5, 2007 | 05:09 PM
gsrboi80's Avatar
Both my GF and I Idle Stepper Look Up tables look like yours. She has an 04 RS
Internal ID: 96420008
Her values are all wacky also
So if you find the fix let me know
Old Apr 5, 2007 | 06:16 PM
elhalisf's Avatar
my 04 GSR is 96420007
Old Apr 5, 2007 | 06:21 PM
gsrboi80's Avatar
Wierd its an 8 at the end of hers maybe thats the problem. Any way what needs to be done to fix it
Old Apr 5, 2007 | 07:48 PM
Ludikraut's Avatar
The table looks correct, but the axis is off.
Here's a snapshot from the 2004 P0300 fix flash:
l8r)
Attached Thumbnails Idle Stepper Look-Up Table Alittle messed up...-96420011_2004_po300fix_iscv_lookup.jpg
Old Apr 5, 2007 | 07:49 PM
Ludikraut's Avatar
^^ looks very similar on a stock 2003 ROM also (94170008).
l8r)
