EcuFlash Read from ECU Button
Old Apr 5, 2007 | 05:33 PM
CafeRCR's Avatar
I've downloaded and installed EcuFlash 1.30 on my laptop running Windows XP without any issues. However when I try to use the software to Read from ECU to get my stock flash and immobilizer code the button is greyed out and not clickable. Any help with this would be appreciated.
Old Apr 5, 2007 | 06:30 PM
MalibuJack's Avatar
1) Are the drivers installed? (Does the lower right corner say the cable is plugged n?)
2) Is the cable a tactrix cable?
3) did the cable get detected when you first plugged it in? And did you plug it in for the first time before starting ECUFlash?
A few pointers to start with.
Old Apr 5, 2007 | 06:58 PM
CafeRCR's Avatar
Thanks MalibuJack, the drivers for the tactrix cable were the culprit. User error strikes again!
Old Apr 6, 2007 | 04:38 AM
MalibuJack's Avatar
It happens really often, for one reason or another the drivers aren't installed, or the cable isn't installed for the first time before launching the app for the first time, so the cable isn't detected and the drivers registered.
Old May 4, 2007 | 08:17 PM
Jorge T's Avatar
I have been flashing without any problems but today I found out that I cannot read the ECU the button is greyed out and not clickable. This is ECU flash 1.30 any help will be appreciated
Old May 4, 2007 | 08:57 PM
nothere's Avatar
did you remember the white plug?
Old May 5, 2007 | 07:51 AM
Jorge T's Avatar
Yes, like I mentioned I can write to the ECU and have done multiple times, just cannot read from maybe missing a xml file in the ECUFlash dir to do this?
Old May 5, 2007 | 08:20 AM
nothere's Avatar
the reason I asked is because it is practice to remove the white plug when not interfacing.
Old May 5, 2007 | 04:14 PM
Jorge T's Avatar
I'm trying to download(read) image file... I've tried with and without white cable plugged in. I can datalog with logworks using open port and Evoscan I do this without the white cable plugged in
Old May 6, 2007 | 11:48 AM
Jorge T's Avatar
What file am I missing that prevents selecting a vehicle therefore not able to read and download rom image?
Old May 6, 2007 | 11:53 AM
nothere's Avatar
wouldn't you select "mitsu 3rd gen evo 7-8"?
please excuse me if I keep bouncing off the obvious.
Old May 6, 2007 | 03:19 PM
Jorge T's Avatar
Dude what I'm saying there is nothing to select the area is blank.....it is like there is a xml file missing.
Old Aug 14, 2007 | 10:15 PM
stockEvoIX's Avatar
I had that problem and it was because I moved the files to a different directory. Once installed, did you move the files or folders around?
Old Aug 15, 2007 | 12:13 AM
oldevodude's Avatar
I would completely uninstall reboot and then reinstall ecuflash. I read somehwere and I think that the rommetadata folder or one of those contain the data for that window. I am really just a noob but if you drill into the program files\openecu\ecuflash folders you will see what I mean. If you have another computer you can install the application there as well to see what might be wrong
Is it possible your cable (the secondary or white plug part) has gone bad between your last write and the latest attempts at reading?
Oh well it's late and im not thinking 100% clear....
Falcon_2003
Jul 1, 2016 07:35 AM
stunt2
Sep 28, 2015 03:15 PM
Rex915
Aug 21, 2010 03:52 PM
06ravenmr
Jun 29, 2008 06:09 PM
ez
Jul 6, 2006 06:13 PM
