Brand New
Old Apr 8, 2007 | 01:28 PM
ddubdb3's Avatar
Brand New
Brand new to tuning and ecuflash...sorry if i make anyone mad for the noob questions. but anyways on ecuflash the load 220,260 etc is based on what i dont quite get what it represents. is there any definitions on all the ecuflash features? also how can i upload my map onto the forum so i can have you guys disect it?? thanks!
Old Apr 8, 2007 | 01:54 PM
TouringBubble's Avatar
The load value you are talking about is based on a calculation that the ECU does and it is based on lots of info from various sensors on the car. Simply put, load is a measure of how hard the engine is working. While crusing at 60, the engine is under a lower load than at WOT in 5th gear.
So, after the ECU determines this load from various sensors, it then uses this value to determine many variables that tell the rest of the components on the car how to function.
For example, if you open one of the fuel maps in ECUFlash, you'll see that each cell in the table is connected to 3 values. RPM on the left, Load at the top, and then a number in the cell itself that represents the AFR. This means that the ECU determines the load, then makes a comparison of that value to the current RPM, and then determines the value of the variable ... in this case, the AFR.
Does that help?
Old Apr 8, 2007 | 03:00 PM
ddubdb3's Avatar
yea that helps alot thanks how can i post the hex files on the forum tho?
Old Apr 8, 2007 | 03:10 PM
you should be able to ZIP the file and attach it here. Why do you need to post you .hex files?
madpacket
Feb 16, 2018 07:26 PM
jb988
May 2, 2016 05:35 PM
ThunderOZ
Lancer Engine Management / Tuning Forums
Aug 6, 2008 05:05 PM
MalibuJack
Aug 23, 2006 04:14 AM
Atlmethevo
Aug 9, 2006 08:18 AM
