Anyone else with these Evoscan problems?
Old Apr 12, 2007 | 05:31 PM
NIevo's Avatar
Well Ive been trying to get my Evoscan.99 to work with my Zeitronix wideband and am having some issues. First of all I cant get it to read my Zeitronix. How are you supposed to set up the wideband? I selected the Zeitronix in the wideband option and it is the right comm port, anything else? It just keeps reading random numbers. Here is a example of a log.
136.2456
followed by 8 lines of 0
7.488
then 7 lines of 0
136.2456
You get the idea.
Next I cant get a running log. It seems the TPS is stuck at 9.0196 and the RPM is 1031.25, the log tracker that shows the received data time on the right works but the logger just keeps repeating those same values. I tried going back and running the installer again and it didnt help. Any ideas?
Old Apr 12, 2007 | 05:55 PM
C6C6CH3vo's Avatar
Yeah,
I got a speeding ticket the other night doing a 3rd gear log.
The cop looked a little surprised - I guess from the mph going from 30 to 85 and back to 40 in 3 - 5 seconds.
Other than that no real 0.99 Evoscan problems
Old Apr 12, 2007 | 06:51 PM
Evo_Jay's Avatar
Originally Posted by C6C6CH3vo
Yeah,
That sucks.
Old Apr 13, 2007 | 07:31 AM
MrEvo2U's Avatar
I have no problems with evoscan .99 and my zeitronix. It was a challenge to get the drivers to work for the serial/usb cable is was using. Can you log with the zeitronix software? If so, it should integrate into Evoscan pretty easily. I ended up using COM4 although everything else was telling me to use COM3.
Old Apr 13, 2007 | 07:34 AM
hksevoix's Avatar
speeding ticket..lol that is a problem
Old Apr 13, 2007 | 08:46 AM
NIevo's Avatar
Im alittle confused about setting up the drivers? My Zeitronix is logging fine through its own program but cant get it to work work with Evoscan. Also the Evoscan is locked up. Does anyone know if I delete my current download of Evoscan and try to download it again?
Old Apr 13, 2007 | 09:34 AM
NIevo's Avatar
Also when you are in Evoscan and you see the Device setup do you have to set anything different? Right now I changed the BaudRate to 9600 for the Zeitronix and the USB cable is checked. However, I have the Zeitronix plugged into the Com1 port, is this why its not working?
Old Apr 13, 2007 | 10:33 AM
MrEvo2U's Avatar
Does your laptop have a serial port; or are you using a serial to usb adapter? If you are using an adapter, you need the drivers for the adapter, then you need to go into device manager for the laptop and designate a com port to be used with the usb. In Evoscan I have the baud set factory at 15625 and usb is checked under device setup. You might also try going to Wideband in Evoscan and 'select wideband serial com port' to make sure everything is all on the right port. Good luck. Also, I have heard that some serial to usb adapters work better than others.
Old Apr 13, 2007 | 12:07 PM
NIevo's Avatar
My laptop has a serial port that I am using for the Zeitronix and only 1 USB port that I am using for the Evoscan.
Old Apr 17, 2007 | 12:27 PM
InsaneEvolution's Avatar
Mine says error from com1. The day before it logged the AEM WB perfect.Everytime I try to log it now the fans turn on till I turn off EvoScan.Oh and all the boxes uncheck.Then I uninstalled it ,reinstalled it.Now it works fine till i try to log the WB again.
Dimmoun
Apr 19, 2016 12:20 AM
hashaam81
Jun 17, 2014 10:09 AM
Eshark
Aug 25, 2013 03:53 AM
uvambo
Aug 8, 2010 09:42 AM
SOEX
Oct 10, 2008 12:28 PM
