Help me decide which wideband
That was the old one the new one reads to 10.0. Its not the best but at the time it was the only one that fitted by needs.
Currently innovate-based WB's are the most accurate among competitors and most durable (the sesor degrades from time and leaded fuel- innovate's wb is possible to recalibrate and it becames accurate again, while other's begin to show incorrect data).
I used to run an Innovate LM-1 and have now switched over to an LC-1/XD-16 combo. The LM-1 is nice if you're only going to plug it in on occasion. The LC-1/XD-16 combo is better, IMO, if you want a permanent install. The new Innovate gauge looks nice.
l8r)
l8r)
I have the Zeitronix and I'm happy with it. The only thing I'm annoyed with is the vaporware release of the 52mm gauge. I bought and installed my ZT2 in January and was expecting the 52mm gauge to be released in February as originally specified on their website. Now we're heading into May and there's still no sign of it.
That said, I'd still buy the Zeitronix again. It's a nice unit. But don't buy it if you're dependent on the 52mm gauge. I've been staring at the empty gauge pod on my steering column for 4 months and counting...
I Dont know which one's better, cause i've only used ZT-2, but i'll recommend zt-2 based on the fact that it can not only log the bosch wideband that it comes with, but also boost and egt if you buy the sensors. If you buy those - the egt is probably the best on the market and the map(boost) sensor will show you true boost that you'll be able to log.
also the lcd screen you can buy with it is the shiznet!!!
TTP Engineering
May 22, 2009 09:52 PM
Bster13
37
Mar 5, 2008 07:28 PM
hawaiian_evo
10
Jul 31, 2006 05:59 PM
Zippo41189
Lancer Engine Management / Tuning Forums
May 26, 2006 10:46 PM
