Evo anti-lag ECU disassembly
Old Oct 4, 2010 | 01:21 PM
  #466
JohnBradley's Avatar
I look for it in a bit, I have the table defs for my car.
aaron
Old Oct 4, 2010 | 01:34 PM
  #467
Maikumaru's Avatar
this is a mod of the scaling right?
whenever you got the info, that would be coo.
I can only imagine what -20 would be like...yikes.
Old Oct 4, 2010 | 01:44 PM
  #468
Its the one that you change 203 to 255 and then I have 2 additional tables as well.
Old Oct 4, 2010 | 01:50 PM
  #469
Maikumaru's Avatar
yes, my scaling is set to 255.
Even inputted -20 for the als portion, but when logging it only shows -10 still...
not sure about the other two tables though. perhaps my work is incomplete.
any luck with the kicker?
Old Oct 4, 2010 | 03:11 PM
  #470
There is one at 0x133f, one at 0x133e and then one at 0x205e. Not sure which one of the 0x133x's you already have.
Old Oct 4, 2010 | 03:14 PM
  #471
Maikumaru's Avatar
ok Ill check it out this week. Perhaps that was missed.
you are logging more than -10 with throttle lift?
Old Oct 4, 2010 | 03:15 PM
  #472
<scaling name="IgnTimingECUa" units="deg" toexpr="61-x*90/256" frexpr="(61-x)*256/90" format="%.1f" min="-30" max="50" inc="1" storagetype="uint16" endian="big"/>
<table name="Ignition Retard Limit #1" category="Timing" address="205e" type="1D" level="1" scaling="IgnTimingECUa"/>
<table name="Ignition Retard Limit #2" category="Timing" address="133e" type="1D" level="1" scaling="IgnTimingECUa"/>
yes, more than -10. Not sure if I have some other tables I have since forgotten about. As it is I forgot there were 3 I had done.
Old Oct 9, 2010 | 08:43 AM
  #473
Maikumaru's Avatar
Aaron,
so I did as you recomended and yes we were able to get -27.
All I can say is holy mother of gawd. I was running around with -10 full time. But with that much negative timing we actually shut it down...was way to much.
-10 is loud, but -24 with a little more air is just plain awesome.
Thanks for the tip.
Working on the map switch that we could never get to work to have on/off...once we can get that to work, the rpm, load and kmph will all be reduced to the minimum to activate the system. Should be nuts
by the way only two maps needed the modification, we could not find the third.
Cheers
Old Oct 9, 2010 | 12:46 PM
  #474
yeah I backed it up to -20 and its VERY poppy. Still working on getting my air valve finish plumbed and wired, UICP is done though. There is also a decel fuel timing retard table you can adjust as well.
Old Oct 9, 2010 | 05:02 PM
  #475
03whitegsr's Avatar
Putting the air around the throttle body but into the intake manifold seems like a bad idea to me. You have power brakes. No vacuum in the intake manifold = lousy brake performance.
Why not just use a BOV like a 1G DSM or metal EVO valve? Using a pull style valve, the exhaust gas would help seat the BOV and prevent a leak. Vacuum in the intake manifold and a drop in exhaust back pressure would pull the valve right open. Disable decel fuel cut and richen up the AFR on decel.
BANG!
Use a switching solenoid to disable it when not desired and a second map with Tephra's patch.
Old Oct 9, 2010 | 05:35 PM
  #476
Biggy VIII's Avatar
Can anyone help with ignition retard limit for 96530706?
changing 173e and 2438 to 255 doesnt help.. still logging -10* of maximum retard,, ((
Old Oct 9, 2010 | 10:33 PM
  #477
evoRS06's Avatar
03 that's similar to what I'm going for, but I wanted to iron out the kinks first before giving a how-to
Old Oct 9, 2010 | 10:56 PM
  #478
BANG!
Best way, but how I am doing mine will maintain vacuum at the booster. Air is fluid and fluid dynamics are predictable especially in a draft (i.e. vacuum inducing situation). Most race cars use dual masters anyway, not that that is my idea. I want this to work with a stock booster and stock power brakes.
Old Oct 11, 2010 | 09:32 PM
  #479
03whitegsr's Avatar
How are you planning on maintaining a vacuum if the air is going through the motor?
Maybe it doesn't take as much air as I'm thinking to keep the turbo going when there isn't an airflow demand or something?
The more I've been thinking about this though, the more interested I am becoming about trying it out. I could really use some boost coming out of low RPM 2nd gear corners.
Old Oct 12, 2010 | 01:04 AM
  #480
leecavturbo's Avatar
its more a case of the inlet plenum will always be at positive pressure (on boost) i don't know how he's planning to get a vacuum ? its an issue the wrc had with ALS don't know how they got over it either . possibly an electric pump to make a vacuum?
apparently diesel cars have vacuum pumps for servo's as diesel don't create a vacuum
