anti lock FLASHING!!!
Old May 7, 2007 | 03:53 PM
evovin's Avatar
I plugged my tactrix cable and the anti lock keep flashing! I am trying to clear my codes but i cant get the scan tool(OBD ll) to work! but i can log on my evoscan! Do i need to do something on the settings?
Old May 7, 2007 | 05:07 PM
draconx's Avatar
unplug the battery?
Old May 7, 2007 | 05:28 PM
AmF_15's Avatar
no dont unplug the battary, the anti-lock is normal, it wil stop after you are like 10-15mph.
Old May 7, 2007 | 05:53 PM
draconx's Avatar
..i dont have that problem.. wtf. must be a 9 thing?
Old May 7, 2007 | 07:54 PM
RazorLab's Avatar
I had that same problem when one of my cables went bad.
Old May 8, 2007 | 08:33 AM
DangerousDan's Avatar
mine always flashes when I have the cable connected, I figured it was normal
Old May 8, 2007 | 09:15 PM
evovin's Avatar
^ do you think its normal that the anti lock is flashing when using th tactrix cable?
Old May 9, 2007 | 05:24 AM
rice_rocket88's Avatar
Never have seen it flash on .. 6 different evos 03/04/05 models.. never tried on a newer model though. I wouldn't think it's a good thing.
Old May 9, 2007 | 05:39 AM
I think it has something to do with the fact that I can't flash my ECU, it is not the same as the evo ECU. Most functions in Evoscan are off too, so most of the proprietary data (throttle position was the first I noticed for instance) from the logs is off. At one point or another I was trying to map out where the obdii port was getting it's signals, I am sure that is one problem. the other problem may be the software for me, I am not sure what processor the ECU uses or if someone is working on a kernal for it or not.
